How to create and inserts a predefined template in the Description field
Qasim Qureshi
July 15, 2025
How can I create an automation that inserts a predefined template into the Description field when the Create button is clicked?
6 votes
Walter Buggenhout
Hi @Qasim Qureshi and welcome to the Community!
Automation can help you set a description after a work item is created, but it cannot inject content into the create work item screen.
You'll need a marketplace app if you want to do that. Here's a marketplace search to get you started. You can also check out this support article for a bit more background.
Hope this helps!
Rick Westbrock
July 21, 2025
We built our own template feature using JSM Assets where the screen has an Assets field where the agent can select a template defined in the Assets schema/object type. Clearly this will only function if you are using a JSM service project but it is an option.
Olivier_OSTConsulting
Hi @Qasim Qureshi
As @Walter Buggenhout mentioned earlier, there are apps specifically designed to meet your needs. I'm sure you'll find one that matches exactly what you're looking for.
I’d suggest taking a look at ours: Issue Templates for Jira Cloud.
Lukas Nicolai_Seibert
Hi @Qasim Qureshi ☺️, Welcome to the community!
To create a default description that appears when clicking on "Create," you can use templating.app. In addition to many templates, we also offer description templates.
This is how this can look like:
You can find us at the Atlassian Marketplace ➡️ https://marketplace.atlassian.com/apps/1224664
Maria Rusnakova
Hi @Qasim Qureshi,
if you have company-managed project, default value for the Description field isn't supported, but you can use a custom field as it is described here: Set Default Description in Jira Cloud Company-Managed Projects.
