How to populate a JSON structure with task & subtask fields
Deiser Service Team
Hello!
I'm doing an automation that will call a REST endpoint with a JSON structure containing a 'header' with info from the task and one 'line' per subtask with info from the subtask.
Output should be something like this:
    "YTXTCAB": "{{issue.summary}}",
    "YWSCYLINSOL":
            "$uuid": "{{issue.subtasks.uuid}}",
            "YITMREF": "{{issue.subtasks.YITMREF}}",
            "YITMDES": "{{issue.subtasks.YITMDES}}",
            "YQTYPUU": "{{issue.subtasks.YQTYPUU}}",
            "YEXTRCPDAT": "{{issue.subtasks.YEXTRCPDATv}}",
            "YCCE3": "{{issue.subtasks.YCCE - Proyecto}}",
            "YTXTLIN": "{{issue.subtasks.descripcion}}"
Where the inner structure is replicated for each subtask inside the array [].
The above example lines do not work, of course, as you get just one line in the array with an all the field values from all subtasks in each field. Like below:
  "YTXTCAB": "TEST - Sage",
  "YWSCYLINSOL":
       "$uuid": "123-abc, 456-def",
       "YITMREF": "YITMREF 1, YITMREF 2",
       "YITMDES": "YITMDES 2, YITMDES 2",
       "YQTYPUU": "1.0, 2.0",
       "YEXTRCPDAT": "2022-02-17, 2022-02-18",
       "YCCE3": "YCCE 1, YCCE 2",
       "YTXTLIN": ""
How would you go about getting one line of the inner structure into the JSON for each subtask?
Jorgen
Deiser Service Team
I have found the solution, pasting it below:
    "YWSCYLINSOL":
       {{#issue.subtasks}}
          "$uuid": "{{uuid}}",
          "YITMREF": "{{YITMREF - Código artículo}}",
          "YITMDES": "{{YITMDES}}",
          "YQTYPUU": "{{YQTYPUU - Cantidad a comprar}}",
          "YEXTRCPDAT": "{{YEXTRCPDAT - Fecha recepción prev}}",
          "YCCE3": "{{YCCE - Proyecto}}",
          "YTXTLIN": "{{description}}"
       {{^last}},{{/}}
