Sign up Log in
How to set stories parent field with Epic?
Jouni Riimala
My Issue structure:
Epic - Requirement (system requirement / user requirement) - Story
I have rule, which summarize Story Estimation values (from story issues) to Epic (Estimate field) & this works. However, if in my stories I don't have Epic in the Parent field then it doesn't work.
Question: How to construct the rule, which ensure if Epic child (ex. story) doesn't have value in the Parent field then it automatically set Epic to child issue (Story) Parent field?
My current flow:
February 4, 2024
Hi @Jouni Riimala
Just following up to ask if the suggested answers solved your question.  If so, please consider marking this one as answered to help others find solutions to similar needs faster.  Thanks!
If not, please explain what is not working as you expected, and post images of your complete rule, the details of the actions, and of the audit log details showing the rule execution.  Those will provide context for the community to offer ideas.
Kalyan Sattaluri
January 19, 2024
Please take a look at @Bill Sheboy answer below
https://community.atlassian.com/t5/Jira-Content-Archive-questions/Automation-I-am-looking-for-a-way-to-sum-Story-points-for/qaq-p/1647852
At a high level, under your branch, you need to do a look up and gather all issues so you can sum up their points.. There is also a youtube post in that thread which I havent looked but may be of help to you.
Jouni Riimala
Thanks from the link, after few modification got it working.
However, solution requires that Epic name (looks like it's Epic summary field value) is assigned to the Story manually so wonder how to set it automatically.
Any guidance within this would be highly appreciated. Willing also to create another rule, which check Epic issuetype using contains link role, which would then set child parent according epic. Current difficulties are within copy field value from the parent and assigning it to the story.
My current flow looks like this.
Jouni Riimala
To make things even more difficult structure is like this Epic - Requirements (system requirement / user requirement ) and then Story so wonder how to get parent from epic to story.
