×I'm setting up a release approval board, and I want to send an email to a specific list of people when all the issues and stories associated with a release are moved to done status. Is that possible in Jira?
Hi @Tim Clark
Just checking... Are you on the Cloud or Server version?
This should be doable by triggering on transition, scanning for any other issues with that fixVersion, and checking their status. This may be more difficult if you have more than one value in the fixVersion field.
Assuming you have one version, you could try this if your change approval is just in time:
If your change approval is a cadenced activity (e.g. every Thursday) you could use a scheduled trigger with JQL. Perhaps something like:
project = myProject AND fixVersion = earliestUnreleasedVersion()
The scheduled trigger approach is much more difficult if you have multiple pending/unreleased versions at one time. UPDATE: I changed the suggested JQL above to use earliestUnreleasedVersion() to help get just the next release.
Best regards,
