Incoming webhook: remove issuelink
Jasmin Müller
November 9, 2020 edited
Hi guys,
I need to link/unlink issues via an Incoming webhook trigger.
For adding issue links, I currently use 'Edit issues' action with the following additional fields:
    "update": {
        "issuelinks": [
            "add": {
                "type": {
                    "id": "{{webhookData.issuelinktype}}"
                 "outwardIssue": {
                    "key": "{{webhookData.link}}"
However, 'remove' is not supported.
I checked the unlink issues action, but I cannot use smart values for the issuelinktype (I have to determine this!) - otherwise I would have to provide a webhook for each possible issuelinktype.
Any other possibilities I missed?
Best, J.
December 10, 2020
Hi @Jasmin Müller
Have you already resolved this?
If not, the only way I found to remove things from list fields (e.g. Component, Labels, Version, Links) is to treat them like strings, and...
  • join to convert to a delimited string, such as CSV
  • use string functions and RegEx to remove the target value(s)
  • as needed, split back into a list before updating a field
Best regards,
