Rules that usually takes couple seconds to execute are taking ~15 minutes to run.
is there anyone facing the same situation ?
Please provide more information when asking a question, so the problem can be identified more easily ;)
- Tessa
How long has this been happening for you? Where’s your instance based? (Region)
hi @Tessa Tuteleers and @Manuel Venegas
Sorry for being non-exhaustive in the original post, I wanted to check if someone was having the same situation as me.
It seems that everything is back to normal now, my rules are executed in usual speed.
I was having this situation between ~11h - 12h french time. I tried different browsers and for 2 different instances (different automation rules...)
I don't see anything major on their statuspage, but something could have been going on that doesn't show here.
Your answers indicate a problem on their side, and since the problem is no longer there, there is little we can do now ;)
Hope it stays this way!
ps: try to add tags to your question whenever possible like "jira-cloud" or something. A lot of users have feeds for specific types of questions, you'll get faster and more answers ;) + other people with similar questions can find it better. I took the liberty of adding some myself.
Tessa
Hello there,
We're currently facing the same issue, so I figured I'd post a reply here. First, let me answer the questions above:
The Automation statuspage says that all systems are operational, but I suspect our issues are caused by our testing of the rules. We use them to put templates into issue descriptions, and to test I've been creating and deleting issues at a high rate. The automation service is now throwing errors on all the deleted issues (which I deleted because the rule had seemingly not worked, and it is set to run at creation time), but it has been doing so for nearly an hour, with intervals ranging from five to fifteen minutes per issue. As I write this, the rules still seem to be slowly chugging away, though the audit log says they're being handled quickly.
