I have the following query in the lookup objects in automation:
objecttype = "Contact" and "Team" = {{"vAssignedTeam"}}
that works when the variable vAssignedTeam does not have a space in the name. When the team has a space in the name, it does not return anything, can someone verify that my syntax is correct?
Hi @Wong
If that is a variable, please try putting the quotation marks around the smart value instead:
objecttype = "Contact" and "Team" = "{{vAssignedTeam}}"
Would you please post images of your complete rule and the audit log details showing the execution? That may provide context for what you are seeing. Thanks!
I am hosted so can not export the log. I split out the automation rule that is not working into a this simple manually triggered automation rule:
Here's the Query:
Here's the log:
Here's the comment, you can see that the variable printed out "Network Services" while the lookup object returns nothing.
Here's the object it should've returned from the Asset schema:
Just to confirm, you are using Jira Cloud, correct?
Would you please show your Create Variable component in the rule? That may explain what is happening with the lookup.
Next, I wonder: smart values are case-sensitive and I suspect the JSM objects are as well. Perhaps change the lookup query to this:
objectType = "Team" AND "Name" = "{{vAssignedTeam}}"
And, after the lookup would you please write these two things to the audit log:
Number of objects found: {{lookupObjects.size|0}}
List of the object names: {{#lookupObjects}}{{Name}}{{^last}}, {{/}}{{/}}
The second one will list just the Names of any objects found, with a comma separator.
Yes, we are cloud. Using your suggestion to log the number of found, I was able to resolve the isssue. It appeared that I just need to add a " " to my variable statement. So, my original variable statement was: {{description.substringBetween("Team:",";")}}.
This was changed to: {{description.substringBetween("Team: ",";")}}, with a space after Team:
This fixed my issue. Thanks for your help in suggesting to log the object found.
