Oauth jira authentication client returns 405 when requesting token
Lingxiao Wu July 8, 2020 edited
Hi all,
I am following instructions at https://developer.atlassian.com/cloud/jira/platform/jira-rest-api-oauth-authentication/ to get the access token for jira api access. However, at the step of requesting temporary token by calling the request-Token endpoint(/plugins/servlet/oauth/request-token), it keeps returns 405 Method Not Allowed for me.  When I changed the method from "post" to "get", this error is gone, however returns null token. So it looks to me my private key and consumer key are passed correctly, so what could be wrong?
com.google.api.client.http.HttpResponseException: 405 Method Not Allowed
at com.google.api.client.http.HttpRequest.execute(HttpRequest.java:1070)
at com.google.api.client.auth.oauth.AbstractOAuthGetToken.execute(AbstractOAuthGetToken.java:73)
at com.atlassian.oauth.client.example.JiraOAuthClient.getAndAuthorizeTemporaryToken(JiraOAuthClient.java:37)
at com.atlassian.oauth.client.example.OAuthClient.handleGetRequestTokenAction(OAuthClient.java:69)
at com.atlassian.oauth.client.example.OAuthClient.execute(OAuthClient.java:51)
at com.atlassian.oauth.client.example.ClientMain.main(ClientMain.java:18)
Process finished with exit code 0
My config.properities file is:
jira_home=https\://jira-test.company.com
consumer_key=userconsumerkey
private_key=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
thank you very much
Sam Harding
July 12, 2020 edited
Hi there!
Firstly, I would strongly recommend you delete/edit this post to remove config.properties information from the post, as it contains sensitive information that you do not want shared.
Secondly, I do not think this is the right place to post this question, as this is the community for the Automation for Jira. I think you're looking for 'Jira' community, so maybe remove this post and repost your question (without the key info) there.
Lingxiao Wu July 29, 2020
Thank you for your response.
I did modify the private key and other confidential info when posting here but thank you for bringing this up
Just an update the issue is fixed by not using string concat for the private key string, instead of converting it to one line string.
