×Hello all,
Is there a function or feature that will automatically sum up the Original Estimate fields for sub tasks into the Original Estimate field in the parent task?
For instance, I have 5 sub tasks underneath a task that I have assigned 1 hour to each sub task. My parent task is just a container and I just want all the times of the sub tasks to populate the Original Estimate on the parent task.
Automation in Jira (Cloud) recently added some subtask-spanning math functions that solve these sorts of problems:
But we are not logging time. we are just entering in Original Estimate.
Bullet 2 in the first link talks about "Sum up remaining estimates or original estimates in all subtasks and set it to the parent task." Sounds like that's what you want to do.
The second link illustrates how to aggregate subtask data into a parent Story (using Story points, but it's the same process).
What you want to do is create a Jira Automation rule which:
{{issue.subtasks.Original Estimate.sum}}
Thus, when any Subtask is edited to change an Original Estimate, the parent Story will get updated to reflect the new total.
Yes, that is what I was working towards, but "Original Estimate" field is not available in the dropdown for Field value changed
Ugh. I assumed that field would be available in that trigger.
Ok, so it took some experimentation and sleuthing, but I think I found a solution.
Start your rule out with this trigger and include this additional conditional early:
I saw some notes that "timeoriginalestimate" might also be relevant for the conditional. You can use the "Audit Log" action to output the {{fieldchange.field}} value and confirm what comes through when you change the field of interest in your Jira instance.
You'll still want the remainder of what I previously outlined:
For others playing along at home, I discovered that the {{fieldChange}} smart value is NOT set when using the "Issue updated" trigger. Grrrr.
Does this look right?:)
So what is happening when this rule is triggered, it is summing all subtasks in my project....
My test Parent is set to 0m for Original Estimate
Then I have 3 sub tasks each
Now, my Parent task is displaying 13w 2d 4h
Not quite. For this bullet:
you'd want to use the following (instead of your "For Sub-tasks" branch):
Also, don't forget about this bullet point:
That should be before the branch. This is because you only want to fall into this branch when the triggered issue is a Subtask.
Sorry, this is the part that I'm not getting. I understand the IF logic (IF sub task exist for Parent) but I am confused how to configure it in this system :) :(
Wow. This was not as trivial as it look originally. I built out a working rule, which looks like this:
But as the thread above shows, the trigger and initial conditional wasn't originally obvious. One last bit of surprise was how the "Edit issue" action needed to be configured:
Note the division by 60, and especially the suffix "m" for minutes.
Internally, Jira stores duration values in seconds. So, we divide by 60 to get minutes, or divide by 3600 to get hours.
Why not just divide by 3600 here and drop the "m"? I tried that first, and the division result was rounded (giving me 8h instead of the expected 8.3h, for example). The documentation doesn't explain this; I might report it as a bug.
The above is tested and works. Hopefully you can find success with it, @Baylor Peak
Note: the above solution assumes your Jira instance is set to use HOURS as the time tracking default unit:
You can check this for your Jira instance (even without Admin privs) using this REST call:
https://YOURINSTANCE.atlassian.net/secure/admin/TimeTrackingAdmin.jspa
(substitute your instance prefix)
If not, adjust the math accordingly.
OK, all that worked :)
One last thing...is there a way for the subtasks sum to be ADDED to whatever is in the Original Estimate on the Parent task?
So, if I have a Parent task that has 2h for that task but then I have a testing sub task of 1h. Is there a way for it to add that 1h to the Parent or is it all or nothing, meaning I can only have the Original Estimate reflect the totals of subtasks?
So the only way to manage that is to create a new custom field for the Stories, which is going to complicate things in a number of ways.
I'm assuming you want to be able to revise the Original Estimate value for the Parent Story/Task itself. In that case, you can't use the same Original Estimate field to also hold the total including the Subtasks.
If the above assumption is not correct, please clarify where I have it wrong. If that assumption is correct...
You have two options for this new field:
I like option 1, as it maintains consistency of what the "Original Estimate" field is across all issue types. It also simplifies the automation rule a bit.
Proceeding with all these assumptions, the rule needs the following changes:
Here's the new computation of the total:
{{#=}}{{issue.subtasks.Original Estimate.sum.plus(issue.Original Estimate)}} / 3600 {{/}}
Note that I've changed this to using a computation {{#=}} total / 3600 {{/}} rather than using the .divide(3600) function. It looks like the function rounds, which I believe is a bug in automation. I'll report that shortly.
Note also that the denominator changed from 60 to 3600. This is to convert minutes to hours.
Here's what the new rule looks like. Note that some of the conditionals have been aggregated for simplicity:
For the two "Edit issue" actions, use the new computation value listed above.
Note that this rule will fire for every issue edit in the configured project(s), but will only update the parent issue when the Original Estimate field changes. Keep an eye on the Usage section of Automation, if your Jira plan has monthly rule execution limits.
I think we are OK there for usage since we only use rules for single projects and not rules that affect multiple projects if I read this correctly.
Single-project rule executions do not count towards your usage. A single-project rule is a rule that automates a task or process that only affects one project.
Also, I discovered our instance is using minutes instead of hours, but our team also round to the hour so we never enter Original Estimate with minute increments. Does that change anything you suggested?
So, lastly, if I create this new custom field for "Original Estimate Total", is this going to mess with my Burndown chart? We don't use Story points nor do we log work time. We solely utilize Original Estimate and then the burn down tracks our progress based on items moved to done throughout the course of the Sprint.
Also, if I have not said it yes, thank you so much for all your effort in this:0 I am also a Salesforce Admin as well as Developer but that is a cakewalk vs this Jira stuff ;) I wish I could just write my own custom trigger :)
Using rules configured for single projects will avoid the monthly execution limits, yes.
I believe the "Default unit for time tracking" only impacts how a bare number like 15 will be interpreted in a Time Tracking field. In my instance it will be 15h, in your instance it will be 15m. The internal storage of that data is still converted by Jira to seconds, so I think all the math above works as shown.
The proposed new field will not impact your Burndown chart at all. Continuing to use the "Original Estimate" field as normally used natively in Jira should keep your reports and metrics consistent and unchanged.
The new field will just provide visibility to the aggregate Original Estimate values at the Story-level, which seems like the original goal.
So all this has brought a question to mind that I have been unable to find a definitive answer.
Say I did nothing, no rules, just base Jira. What does Jira do natively on a Scrum board regarding sub-tasks? Meaning, if I have a parent task that has 4 hours for the Parent task and then 2 sub tasks each 1 hour, is Jira already calculating the sub tasks for the overall length of the Sprint, or is it only looking at what is in the Parent Original Estimate field?
So there are some places where Jira aggregates things like this, but it's not as universal and complete as we might wish for.
You've discovered, for example, that Original Estimate values in Subtasks aren't natively aggregated relative to their parent Story or Task in a visible way in issues.
If you are using the native Jira Time Tracking (not an add-on App like Tempo Timesheets), then at the Story/Task level the "Time Tracking" field does show an aggregate that includes subtasks. But that's not a real field, it's a visualization.
Values like Time Remaining are also internally aggregated in a way that provide value in a Burndown chart.
When issue searches, there are these three fields available which make aggregated data visible, but they are computed/internal value, not editable fields:
You'll probably find that many of the built-in reports (burnup, burndown, sprint report, epic report, etc) will aggregate the estimates as you expect.
The lack of visibility to some of that data at the issue level is sometimes confusing.
Hello @Mykenna Cepek
I'm looking all over for this solution (sum subtasks original estimates into parent's original estimate field)
I've tried the exact same automatin you suggested above, even changed the default unit for timetracking to make sure all would work the same way...
Well, the parent's original estimate field keeps getting updated with the value 0.
I even added an action of commenting the issue with {{issue.subtasks.Original Estimate.sum.divide(60)}}m, and that only confirms it keeps adding 0 to the original estimate.
Do you have any idea why this might be happening?
Hmm, hard to say for sure with just this information.
Some things to try to discover more about what's happening:
Hope that helps you figure it out!
I'll add to the chorus of grateful people and say thank you @Mykenna Cepek!
I was having trouble with this exact use case and it turns out my automation wasn't working because I had
{{issue.subtask.Original Estimate.sum.divide(60)}}m instead of
Such a small difference but without the 's' on the subtasks, the rule wouldn't run properly!
Very much appreciate you posting the successful rule.
I spent many hours searching for this. It worked perfectly here. Thanks a lot @Mykenna Cepek You're phenomenal.
Thanks for this explaining @Mykenna Cepek 🤝
