Pull request created automation trigger is not working
Julie Shepard October 2, 2024
We have a team-managed project in Jira with a number of automations that were working for years and suddenly stopped a couple of days ago.
One of them is – when a PR is created, check labels, go to github to fetch this PR (to get the author's name) and send a notification to Slack. Since a couple of days ago there have been no audit logs added at all.
I started investigating and created a new simplified automation that just sends a plain text Slack message when a PR is created. I have the issue code in the branch name, PR title and PR description. This automation doesn't run.
However, when I change the first step from 'Pull request created' to "Branch created" or "Issue commented", it works fine.
Would anyone be able to assist?
October 3, 2024
Hi @Julie Shepard -- Welcome to the Atlassian Community!
There is an open incident related to this symptom, which you may follow here:
https://jira-software.status.atlassian.com/incidents/wcs79hfp1npb
If your rule continues to have problems after that one is resolved, I recommend working with your Jira Site Admin to submit a ticket to the support team: https://support.atlassian.com/contact/#/
Julie Shepard October 3, 2024
Thank you for this information Bill, looks like that could be the reason why we're having issues.
We'll see how we go when it is resolved.
Like Bill Sheboy likes this
PARISATO Marie-Hélène
vous avez pensé à vérifier si vous n'aviez pas dépassé la limite en nombre d'exécution ?
Dana Pliavinska October 3, 2024
as far as I know there are no limits on automation rules in the premium plan
I tested a bit more today and noticed that it only affects some of our github repos and works fine with others.
Is there anything anywhere I can reset per each repository to make it work again?
Dana Pliavinska October 2, 2024 edited
Hey! I have the sane problem. All automations that successfully been working for a while suddenly stopped working on September 17th
