Hi community,
i'm new in this automation process and found no template and the automation could help me.
I would like to postpone an issue.
IF there is a "due date" AND the "due date" is exceeded
THEN reopen the issue
This would be essential to my service desk project
Hi @Janek Häßler ,
welcome to the community!
I would set up an automation scoped to your service project or projects with a scheduled trigger that runs once a day with the following JQL:
duedate <= now() AND statusCategory = Done
This should identify all issues currently resolved or done with an expired due date. With a edit issue action you can now transition these into your desired status.
Instead of closing and reopening you could use a status like "pending" . In your SLA configuration you can pause SLA while in pending.
Hope that helps!
It helped a lot and I also learned a lot here.
It now works (and I'm fixed to do even more).
Thanks David !
If you want to check if the duedate has been exceeded, wouldn't you want to select issues where the duedate is before "now"?
duedate <= now()
Also, you would use the Transition Issue action, not the Edit Issue action to change the issue status.
Hey Trudy, yes - I already checked it, also that I cannot {{null}} the due date during the transition to change the status. It has to be a second step.
And my trigger filter is:
duedate <= now() AND project = "<name of project>" AND NOT status IN (Resolved, Closed)
@Trudy Claspill you are absolutely right! I corrected that little mistake in my answer to @Janek Häßler . Thank you!
