Rovo Agent Response String To JSON
Chance Douglass
I am trying to treat the response from a Rovo agent as a JSON object and reference it using dot notation.  I have the agent response formatted correctly. Excerpt here:
{ "documentStatus": "PRD In Process", "documentOwners": [], "projectStatus": "", "prfaq": "", "epicTicket": "", "targetRelease": "", "designer": "", "techLead": "", "relatedDocumentation": [], "termsAndDefinitions": ""}
but I am unable to access any of the information outside the entire response.
I have tried using the 'jsonStingToObject()' method both as an entire variable creation and individually in line during the automation.  I can not get any results with the jsonStringToObject call either in dot notation, or for the entire string.
Anyone here had success with either of these methods? Or know of a better one?
Alex Gallien
June 23, 2025
I came across this while trying to solve the same problem. The workaround that seems to have worked for me is saving {{agentResponse}} as a variable then passing that variable to the jsonStringToObject() function. From there I was able to use dot notation to call other values in the JSON that Rovo returned to me. Hope that helps you too!
July 9, 2025
Hi @Chance Douglass
Just following up to check if this answered your question.  If so, please consider marking this one as "answered".  That will help others with a similar need find solutions faster.  If not, please let the community know what help you need with the rule changes.
Thanks, and kind regards,
Like Walter Buggenhout likes this
Marc - Devoteam
June 17, 2025
Hi @Chance Douglass
I'm not sure but are the agent responses JSON, I think they are text.
Do you get results, when using {{agentResponse.documentStatus}} or even simpler {{agentResponse}}
What are the responses?
