Rule has stopped functioning
Paula Manildi October 28, 2021 edited
Rule was created so when an issue is moved to Under Review, and is a Change Request, an email is to be sent to Devops. It was working. Then turned off. When turned back on, it has not started working. I even recreated and that rule is not working. What am I missing?
Andreas Knecht
October 28, 2021
Hi @Paula Manildi ,
Is your workflow transition configured with a custom event by any chance? You can see this in the workflow's post-functions.  It should be firing a 'Generic event'.  If it's any other type of event then this wont work currently due to a limitation in Jira Cloud, where Jira wont trigger a workflow transition event if a custom event type is used!
Andrears
That was it! it was a custom event, I changed it to a generic one and it works now
Darryl Lee
Do your Audit logs show anything?
It's useful to add Logging before and after the IF clause to see things the values of things like: {{issue.status.name}} and {{issue.issueType.name}}
Mykenna Cepek
October 28, 2021
If the Audit Log for that rule doesn't show errors or executions when expected, confirm that the rule is enabled.
If it is enabled, then maybe check your Automation usage to ensure you haven't exceeded any limits for your plan:
