Hi @Pétur Björn
You could do something like this with Automation for Jira:
Hope this helps
Best regards
Sam
Hi @Pétur Björn
It is possible to define SLA metric for closure time. Then, in automation, when SLA breached, transition issue to closed.
Alternatively, you can use Scheduled trigger and provide a JQL which finds issues waiting then x amount of time without an update, then again change the status to closed via Automation.
