×Hi Britney, welcome to the community.
Sure, there are actually several ways to do it. The way I like to set it up is by defining an SLA that starts once status changes to Waiting for customer. Then an automation can be set up that triggers as the SLA is breached or about to be breached. As the clock is ticking down you can have an automation write public comments to the ticket as an reminder for the customer. Once the SLA is breached, an automation simply changes the status to the resolved status or whatever workflow status you have defined.
Hi, David could you share a screenshot of what the SLA would look like for this? I've added the "waiting for customer" status into our workflow but now I'm trying to create a new sla.
Hi Britney, this looks good. Yes, you would need a different trigger to close the work item. Here is an example with the SLA breached trigger:
And this is an example for the "Waiting for Customer" SLA:
The advantage of using an SLA rather then a scheduled trigger in an automation is that you can define a calendar with your business hours.
omg, you've been so helpful! Thank you! I have one more thing that I'm trying to figure out..I added the "waiting for customer" status into the workflow but when I put my tickets in that status, it automatically wants to send it to ' resolved' I'm attaching a picture..I'm trying to set the status to 'waiting for customer' and it stays there...
From the picture you added I can not tell why. But you say it wants to send it to 'resolved'? The status after 'Waiting for Customer' is 'Done' not 'Resolved'...
Maybe you have other automations in place that might be triggering?
What does the transition on the waiting for customer status do that points to itself?
Hi @Britney
Please accept my answer as a solution, if my answer helped to solve your request.
This will help other community member trying to solve the same.
P.S. If the answer is very valuable to you, please share some kudos.
