Smart value on a branch
Benjamin aka B.M
June 5, 2024
When using "For: linked issue" I want to use something like {{ branchIssue.field }} and not something like :
{{#issue.issuelinks}}{{#if(equals(type.inward,"is implemented"))}}{{inwardissue.key}}{{/}}{{/}}Capture d’écran du 2024-06-05 10-19-59.png
Is there a way ?
June 5, 2024
Hi @Benjamin aka B.M -- Welcome to the Atlassian Community!
Would you please explain what problem you are trying to solve with the rule?  Knowing that may help the community in offering suggestions.  Thanks!
Until we know that...
Once inside a branch on issues, {{issue}} refers to the branched-to issue as it loops.  There would be no apparent need to access them by the issuelinks smart value.
What is not working as you expected?
Benjamin aka B.M
June 6, 2024
Yes it was a misuse from my part, can't delete my post but it's as you said, {{ issue }} is refering to the issue in the branch
Like Bill Sheboy likes this
