State Transition Error
Arslan Hafeez
April 26, 2022
I am having an issue in state transition. The subtask is created with "Open" state but I want it to be created with "AC Refinement" state. This state come immediate after "Open" state in workflow.
Note: I have a different workflow for subtasks. Manually I can shift from "Open" to "AC Refienment" after creation of subtask but I want to achieve it with automation.
Arslan Hafeez
April 27, 2022
@Sam Bartolome  Thanks. That works.
Sam Bartolome
April 27, 2022
@Arslan Hafeez
If it works, could you set the answer as valid?
Sam Bartolome
April 27, 2022
Hi @Arslan Hafeez ,
Welcome to the Atlassian Community.
The above automation  is telling the current issue (parent task) to move to AC Refinement, reason it fails (error) and the sub-task is not transitioning
You should use branching as below to accomplish what you are looking for
