To copy custom fields to subtasks
Mario Amaya December 14, 2023
Hey guys, do you know how can I do in the automation to copy a custom field from the Issue
I mean, I have an issue created, when creating a subtask from that issue, I want a custom field to be the same as the parent issue, you know?
Mayur Jadhav
December 14, 2023
Hi @Mario Amaya ,
I hope you are doing well!!
Atlassian has document on how to create automation rule to copy the parents field data to a sub-task.
Automation : Copy custom field values between subtasks and parents
@Mark Segall mentioned in his answer just change the trigger point.
Mark Segall
December 14, 2023
Hi @Mario Amaya - So you're creating the sub-task manually, and upon creation you want automation to copy field data down?
You could do something like this:
  • TRIGGER: Issue Created
  • CONDITION: Issue Type = Sub-Task
  • ACTION: Edit Issue
    • Select your field
    • Click the ... menu
    • Select Copy
    • Change the source to Parent
