×I want to create an automation that triggers on either adding OR editing a comment. In Jira Cloud, the "Multiple Issue Events" would seem a likely place to look, but the options include neither comment added nor comment edited.
How to create ONE RULE that would operate on a comment (whether added or edited).
The goal is to extract @ mentions and add these to the Watchers list -- I have a rule that can do this but I seem only to be able to trigger it from EITHER comment added or comment edited.
Hi Eric,
Yes, you are correct that you would need two rules. Is there a particular reason that you want to combine them? (Other than the obvious one of less maintenance).
