I have a Rovo Agent that creates a wiki page on each run. It is tested and runs perfectly on demand. I want to automate the agent to run daily using the Automation feature. I created the rule with the schedule and "Then: Use Rovo Agent" I included the same prompt that I use to manually run the Rovo Agent in the Automation required prompt field.
I verified the rule and got the green check for no errors. When I run the rule manually, I always get a green "success" in the status with about a 20-30s run time; however, it never creates the wiki page.
Suggestions?
