"I have a custom value, such as a sasNumber, that I need to send to my API when an object is created. How can I include this custom value in the HTTP request Post Data?"
Hello, @Mustafa Karacabey ! Welcome to the Atlassian Community!
I'm not sure if I understood correctly. Do you mean how we can build the JSON to send via web resquest? If that is the case, we have to build a JSON structure using the objects. Here's an example of s JSON sending the project key, summary and some custom field information via POST.
"fields": {
"project": {
"key": "TEST"
"summary": "{{issue.summary.jsonEncode}}",
"customfield_1234": "{{issue.key}}",
"customfield_4321": "{{issue.customfield_10093.jsonEncode}}",
"customfield_0001": {
"value": "{{issue.fields.customfield_10248.value}}"
Let me know if that helps.
Actually, ı try to get payload jira Insight Asset Management Automation module, ı could not get any custom values from object created event
