×Hello,
I am working on a rule using API calls to check if something still exists in one of our tools. I have been able to use regex successfully in the past to pull so many things out of webhook responses. BUT this time is different. I am looking to identify when something doesn't exist in the tool anymore, since the tool wipes it out I get a 404 error back from it. I was hoping to use that error message to then close corresponding Jira tickets that were associated with the deleted object but I can't figure out if I can use that as a condition to then perform an action.
It does seem like the rule just stops when it reaches that error so I am thinking that will be the answer but thought it was worth a shot to ask!
I am happy to provide whatever I can from the rule just let me know what would be helpful.
Thank you,
Josy
In the Send Web Request action, there is an option to continue processing after an error:
Continue running the rule even if the request response is not successful (i.e. non-200 response)
When that is enabled you could use the response code with conditions to decide next rule steps.
Oh wow, I always miss those boxes! Thank you for the quick and helpful response.
