automation Scheduled not run
zhangqian04
hi ,
      Using  ‘ScheduleCron expression ’, not run .
Alex Koxaras -Relational-
Hi @zhangqian04
I little bit more info would come in handy, as @Alexander Pappert stated.
zhangqian04
rule log has no record  and restart has no effect.
system log is :
com.codebarrel.jira.plugin.automation.schedule.RuleInsightsUpdateScheduler.DAY.scheduler.
Job runner key 'com.codebarrel.jira.plugin.automation.schedule.RuleInsightsUpdateScheduler.DAY.scheduler' is not registered
How to solve it ?
Thanks.
Alexander Pappert
August 4, 2021
whats your cron?
you can use pages like this to create cron expressions
http://www.cronmaker.com/?1
zhangqian04
It works well all the time. Suddenly, it doesn't work one day. After disabling and restarting, the plug-in doesn't work.
cron:  0 30 10 ? * MON-FRI
Alexander Pappert
August 5, 2021
so, the problem is not the cron expression, it is the automation addon?
then try to restart it again
check also the rule log for possible errors
zhangqian04
system log is :
How to solve it ?
