how to automate a proces of converting sub-task into bugs?
qba
June 6, 2025
I have a challange in my organizations - need to automate one proces.
Every time when sub-task is created - I need to convert it to BUG and add some special fields. Adding special fields is not a problem but cant set a triger for converting a sub-task into BUG. Thank you for help.
Akriti Sagar
June 6, 2025
Hi qba
Thanks for your question.
You're right—Jira doesn’t allow changing the issue type (like from Sub-task to Bug) automatically using built-in Automation. But here are a couple of ways you can work around it:
Option 1: Use Automation + Clone
Since we can’t directly convert a Sub-task to a Bug, we can automate cloning the Sub-task as a Bug, and then delete or close the original sub-task.
Steps:
Go to Project Settings > Automation.
Create a new rule:
Trigger: Issue created
Condition: Issue Type = Sub-task
Action: Clone issue
Set Issue Type = Bug
Add your special fields here
(Optional) Add another action to Transition or Delete the original sub-task
This way, every time a sub-task is created, a Bug will be automatically created with the same content + your custom fields.
 Option 2: Use ScriptRunner or Other Apps
If you're okay using a Marketplace app like ScriptRunner, you can write a script to change the issue type directly. This is more flexible but needs admin access and scripting knowledge
