Help set up automation of the start date and end date of the task, so that when you start working with the task, the date is set automatically in the start date field and when the task is closed, the date the task is closed is set.
I'm still new to Jira and therefore I still don't understand everything well, I need your help.
When you start working on the task, let us say by clicking workflow transition button (Start Progress or something similar) then that is already stored in Jira. Similarly for end date. Also there is a Resolution date.
Yes you can automate to capture these dates and update custom fields. In your automation rule you can use transition trigger and update your date fields using smartvalue {{now}}, but I don't think it is necessary because the dates are already there in Jira which you can fetch and report on.
I hope it helps.
Ravi
СThanks, it helped me a lot, but I can't re-add the task state trigger. Can you suggest how to do it?
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
