×we have jira cloud and bitbucket
the integration is working fine - i can manage and see the details of the branch and pull requests in jira as needed
in the automation rules, I would like to get teams notification when a pull request is created for a specific destination branch, but all the values i get for the {{pullRequest}} smart values are empty, so no trigger and the msg is actually empty
(the notification in teams works fine)
rule configuration I tried:
jql to filter key=XXXX (one that i know has a pull request, and i can see it in jira)
send teams msg with info:
{{pullRequest.destinationBranch.url}}
{{pullRequest.destinationBranch.repository.name}}
{{pullRequest.destinationBranch.repository.url}}
{{pullRequest.createdDate}}
{{pullRequest.state}}
{{pullRequest.url}}
{{pullRequest.destinationBranch}}
the msg is sent but the info is empty
any idea what im doing wrong?
Can you add a screen shot of your automation rule's trigger and the action that you've mentioned.
As per https://support.atlassian.com/cloud-automation/docs/jira-smart-values-development/
These smart values are only available for the Pull request created, Pull request declined and Pull request merged triggers
Also, to debug is a certain value is present would recommend using the 'Log Action' action to see if thr smart value actually has a value or not.
tries the log-action, same result - empty values
my trigger at the moment is a scheduled trigger, where the jql: key=<my issue that has pull request merged>, and i trigger it manually from "run rule"
the log-action:
{{pullRequest.destinationBranch}} {{pullRequest.destinationBranch.url}} {{pullRequest.destinationBranch.repository.name}} {{pullRequest.destinationBranch.repository.url}} {{pullRequest.createdDate}} {{pullRequest.state}} {{pullRequest.url}}
and in the log i get empty msg.
Thanks for the image @Emily Pinhasi
You will have to update your automation trigger as https://support.atlassian.com/cloud-automation/docs/jira-smart-values-development/
Try setting it to Pull request created, Pull request declined and Pull request merged and then retry please.
oh I see the problem, thank you very much
changed my trigger, waiting for someone to merge a pullrequest :)
Great,
If the automation works after the change, please mark this thread as Accepted, so that it's more visible to the rest of the community
