remove label after editing
Cedric Ahrend
June 28, 2024
Hey all,
I'm just starting with Jira as Product Owner and I'm trying use automation to speed up my work process. Every time a story is created a lable "toBeRefined" is automatically added, to help me with Backlog Refinement.
Then I have to manually remove the label, once refined which is a source for errors and confusion, if I forget to do it. So I tried the JSON field with automation to remove the label every time I edit an issue and enter a value in Story Points.
The Audit logs keeps telling me there's an 'Error while parsing additional fields. Not valid JSON.'
{ "fields":
               { "environment": "Thanks for raising {{issue.key}}.",
       "labels": [
                "bugfix",
                "blitz_test" ],
            "update":{
               "labels": [ { "remove": "toBeRefined" } ] },
               "Custom Field Name": { "value": "red" }
For automation I use
When: Value changes for Story point estimate, Story Points
Then: Edit issue fields Labels, Advanced
What am I doing wrong here?
June 28, 2024 edited
Hi @Cedric Ahrend -- Welcome to the Atlassian Community!
There appears to be both some leftover JSON, from the field template, and incorrect syntax for label updates.  Please look here for the correct syntax to add / remove labels: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Labels
And...from what you describe, you do not need JSON for this scenario.  Instead, you may remove the JSON, select the Labels field from the dropdown list, and at the right side ... menu select the ADDREMOVE option.  That will allow you to enter the specific label in the Values to Remove field.
Cedric Ahrend
July 5, 2024
Hi @Bill Sheboy -- thank you :)
the ... menu solution did the trick, thank you very much!
Kind regards
Cedric
Like Bill Sheboy likes this
