scriptrunner script to reset single select custom field value on system field assignee change
Dayanand
Kindly help us with below script
script to reset single select custom field value on system field assignee value change
Tried behaviour but on edit popup also its resetting single select custom field value which we dont want only on system field assignee value change the custom field value should be reset
def assteam = getFieldByName("Assignee Team")
if (getFieldChanged())
{ assteam.setFormValue([-1]) assteam.setRequired(true) }
Dayanand
Any help appreciated?
