Docker Build Kit Secrets throwing unexpected error
LHernandez December 15, 2022 edited
Help with this would be appreciated!
I'm using docker build kit to pass build secrets.
I'm replicating the documentation found here
The 2 secrets are present in repo vars and they are secure.
My pipeline step looks like this:
I'm getting the following error message:
could not parse secrets: [id=WEBLOGIC_ENCRYPTION_SECRET id=WEBLOGIC_ENCRYPTION_SALT]: failed to stat WEBLOGIC_ENCRYPTION_SECRET: stat WEBLOGIC_ENCRYPTION_SECRET: no such file or directory
Theodora Boudale
December 19, 2022
Hi @LHernandez,
I haven't been able to reproduce this error so far with a Docker runner and a command similar to yours, the only time I can reproduce this is if the variables do not exist.
I see that you are using a runner for this step.
  1. Can you please confirm if this is a Linux Docker Runner?
  2. What version of the runner are you using? You can find that in the Pipelines build log in the section Runner.
  3. What is the version of Docker on the machine where the runner is running?
  4. Are you using a custom docker-in-docker image for the docker service in the bitbucket-pipelines.yml file?
  5. What output do you get if you add the command docker --version in that step in the bitbucket-pipelines.yml file?
Theodora
