I see that to install stash as a service, it requires that JAVA_HOME point to a jdk. I'm installing Stash on a server that already uses the JAVA_HOME (pointing to a jre) variable for other applications. Is there an easy way to make stash look for a different variable?
Many thanks to C.Faysal for prompting the research.
I ended up having to set JAVA_HOME in service.bat and point it to the jdk. The environment variables were left with JAVA_HOME pointing to the JRE.
hi.
try the search function for example :)
https://answers.atlassian.com/questions/137702/how-do-i-configure-stash-to-use-a-specific-java
Thanks for the quick response! This article looks like it addresses the setenv file, which Stash ignores when installed as a service.
Is there a way to make Stash use "JAVA_HOME_JDK", for example, instead?
I just tried using the SET command in the setenv batch file to point to the JDK but it doesn't seem to work. When you say "init script", are you talking about "startup.bat"?
Thanks again for helping out with this.
Apologies - should have mentioned - installing on Windows. Would this just need to be set in start-stash.bat?
EDIT: Just noticed that start-stash.bat doesn't reference JAVA_HOME, so my guess was probably incorrect. Although, it does appear that service.bat references a JAVA_HOME and JRE_HOME. Would setting in this file help?
I set the variable in service.bat, ran the bat to install the service, and everything is working great. If you want to post this as an answer, I'll mark it as answered so you can get the points.
Thank you so much for such quick responses. I really appreciate it.
Java home environment variable for windows install service (Service.bat) is different for JDK and JRE.
For JRE change environment variable "JAVA_HOME" to "JRE_HOME"
Read Service.bat for details on the difference.
Josh,
Looking at the installation instructions for Tomcat (which Stash uses), you should be able to do:
tomcat7
//US//STASH --JavaHome <path-to-alternate-java-home>
I haven't tested this though.
Michael
Sorry, I meant to mention service.bat. It still seemed to ignore setenv.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
