Problem with pipelines on /opt/atlassian/pipelines/agent/build/node_modules/mkdirp/index.js:4
gastonfournier April 5, 2020
My pipeline has been running smoothly for a long time, but on March 21 it started failing with no code change on my side.
I'm using the image maven:3.3.9 for the pipeline which is just running mvn -B package with frontend-maven-plugin for minifying and versioning assets (https://github.com/eirslett/frontend-maven-plugin).
The error I'm getting is at the execution of that plugin:
[INFO] --- frontend-maven-plugin:1.0:grunt (grunt build) @ ... ---[INFO] Running 'grunt build' in /opt/atlassian/pipelines/agent/build[ERROR] /opt/atlassian/pipelines/agent/build/node_modules/mkdirp/index.js:4[ERROR] const {mkdirpNative, mkdirpNativeSync} = require('./lib/mkdirp-native.js')[ERROR] ^[ERROR] [ERROR] SyntaxError: Unexpected token {[ERROR] at exports.runInThisContext (vm.js:53:16)
Locally, it works fine with maven 3.6.0, so I tried to upgrade the image to maven:3.6-jdk-8 with no success.
Have someone else faced this problem?
And it was a dependency issue from node (used by the plugin):
- "grunt": "^1.0.1",
+ "grunt": "1.0.4",
Forcing the previous version of grunt solved it.
gastonfournier April 5, 2020 edited
Ok, comparing last successful execution with the first one that failed, I noticed that grunt dependency changed from grunt@1.0.4 to grunt@1.1.0
And mkdirp@0.5.1 updated to mkdirp@1.0.3 which is inherited from that version of grunt.
I also noticed Cache "maven": Not found in the errored build.
Now I'll try to check why since grunt comes as a dependency of frontend-maven-plugin.
I'll update if I manage to find the solution
atlassian, state of devex 2025, developer experience, devex report, developer productivity, ai in software development, engineering challenges, team collaboration, internal developer platform, time management, developer survey, space framework
Atlassian State of Developer Experience Report 2025
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
