view outputs from atlassian/bitbucket-build-statistics:0.1.0
Deleted user December 2, 2020
I'm new to pipelines, which is probably part of my issue.
Following the blog post introducing this pipe:
 https://community.atlassian.com/t5/Bitbucket-Pipelines-articles/Bitbucket-Pipes-digest-October-2020/ba-p/1508196
I've created and deployed a pipeline using the template yaml file.
script:
  - pipe: atlassian/bitbucket-build-statistics:0.1.0
    variables:
      BITBUCKET_USERNAME: $BITBUCKET_USERNAME
      BITBUCKET_APP_PASSWORD: $BITBUCKET_APP_PASSWORD
where I've used my username and app password.
The pipeline runs and completes successfully, but I do not see any report on build statistics. Where is the output shown?
I've also tried adding the filename option.
  script:
    - pipe: atlassian/bitbucket-build-statistics:0.2.0
      variables:
        FILENAME: "build_usage.txt"
Where would I find the output file?
Halyna Berezovska
December 3, 2020
@[deleted] it should be found inside current working dir in the pipeline.
How you're looking for it?
Try $(cat build_usage.txt) .
I executed this and succeeded.
Also, it depends on what should be done after. Now the pipe just outputs this to given file and to stdout, both.
Regards, Galyna
Deleted user December 3, 2020
@Halyna Berezovska
I run the pipeline from the bitbucket web page by clicking the "run pipeline" button at the top of screen.
this does not give me access to a terminal or to command prompt (or if it does, I don't know how to access them).
Without terminal access, I do not see the output to stdout, nor do I know how to access the file, since I don't know what filesystem the file is on or how to access that file system.
What filesystem does the pipeline run in? How do I access the file system?
The full pipeline is (the cut/paste destroyed the yaml indents)
# This is an example Starter pipeline configuration
# Use a skeleton to build, test and deploy using manual and parallel steps
# You can specify a custom docker image from Docker Hub as your build
environment.
image: atlassian/default-image:2
pipelines
custom:
getUsage:
step:
name: 'Get pipeline usage'
script:
echo "Running usage monitor.."
variables:
BITBUCKET_USERNAME: XXX
BITBUCKET_APP_PASSWORD: XXXXXXX
Deleted user December 7, 2020 edited
Ok, I figured it out. If I look at the output of the build log, I can see that the pipe: atlassian/bitbucket-build-statistics ran for 21s. Clicking the little arrow on the far right opens the log output. The needed data is there, at the end of the log output.
Halyna Berezovska
December 7, 2020
@[deleted] exactly. Contact us if you want to raise more questions.
Cheers, Galyna
