How do I add custom background colors on info panels?
Laura Derksen August 2, 2022
I'd love to set custom background colors for my info panels to match my company brand. Does anyone know how to do this?
Dominic Lagger
August 3, 2022
Hi there
This is not possible. The only colors available are these you showed in the screenshot.
Regards, Dominic
Laura Derksen August 4, 2022
Ah, too bad.
Thanks for your response!
Christian Burger
June 21, 2024 edited
Not sure if still relevant, but I found it possible to change to a color code of my choice by using the Confluence REST API and adding the macro manually to the Storage Format of the text by eg replacing a unique text: with something like:
<ac:structured-macro ac:name="panel"><ac:parameter ac:name="bgColor">#03a9fc</ac:parameter>
<ac:rich-text-body><p /></ac:rich-text-body></ac:structured-macro>
That is not convenient really, but once it is placed on the page you can at least copy it. Obviously this is no match for the possibilities mentioned in the Apps.
With this mechanism and using the title parameter you can also add a title to the panel.
Best regards,
Christian.
Graham Carrick May 6, 2024
Another third party option is the Crafted Panels for Confluence app It provides a range of different styling options for panels including support for content like tables inside panels.
Zoriana Bogutska_Kolekti-Adaptavist_
September 19, 2022 edited
Hi @Laura Derksen
If you would like to have more options for customisation your content at the confluence, you can try using third-party solutions from the Atlassian marketplace.
One of them is Content Formatting Macros for Confluence.
It allows to create pages with branded backgrounds, buttons, and cards with custom colours.
If you are interested and need help let me know as this app is developed by my team and we want to help customers have a better experience.
