Making format option "Code" a bit more visible?
Lynoure Braakman August 7, 2024
In the company we have pages that have just tiny fragments of code, say a path to a file, Unix permissions or a single line command. However, when using the "Code" format option, the result looks extremely similar to normal text making these important pieces of information hard to spot. Yet a code snippet would be an overkill.
Is there any way to increase the visibility of the formatting, say by having a different background color by default?
Barbara Szczesniak
August 8, 2024
@Lynoure Braakman For a more distinct contrast, you could apply a highlight color (or even a combination of text color and highlight color).
Note however, that this does not change the font of the text to a monospaced font.
Shawn Doyle - ReleaseTEAM
Hi @Lynoure Braakman
When using both the code snippet and the code macro (ctrl + shift + M),  I get a different background color, it's not a drastically different color, but it's still noticeable, I do not believe there is a way to customize this further without a Marketplace addon.
Lynoure Braakman August 8, 2024
I'll only address the light mode, as that's what our Confluence uses.
With the Code Snippet, the line number area ( with #E3E5E9 ) does stands out sufficiently. A single word in a text with 'Code' formatting option, with only the background color, really does not on very many monitors.
For example, on a new Dell laptop screen, I can see it. The brand new Dell external modern midrange monitor? Not even a chance. The difference is so subtle, that only if I know where to look at, I can just barely notice the background being a different shade.
For myself I can choose to have Confluence only on my laptop screen (though that's a huge pity), but I cannot enforce that on anyone else.
The code background seems to be #F1F2F4, even lighter than the standard "light gray" (#E8E8E8) and it's meant to stand out in contrast to the standard background of  #FFFFFF.
The curse of UI designers is that they typically have way better monitors than average office workers.
FREE
Register now
