×I was not able to understand most of the parameters set for chart macro in confluence. Please give me detailed explanation of each parameter, If possible with examples please.
Hi @Lingamgunta Sai Sri Nymisha ,
Welcome to Atlassian community.
Below page has all the info regarding Chart macro. You might want to go through the same.
I hope above helps. Have a good day!
Srinath T
Hi Srinath,
Thanks for the response. But that didn't help at all as i had studied it a lot of times from yesterday. I exactly want to know what each parameter is? For example, what are TABLES and COLUMNS parameters specify??? The description is also not clear and specific. so don't know on what basis it has to be filled and not just these two, most of the parameters are same. If you or anyone using the chart macro successfully, please let me know the details for Parameters you have set.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
