Hello Everyone!
Everything I have found so far indicates that I should probably talk to support about this, but I thought I would ask directly just in case someone knows the answer.
My company is looking to upgrade our Confluence Cloud Premium to Enterprise.
However, this exists on the same site as our Jira Software & Jira Service Management which they intend to keep at Premium.
My question is, can we actually run mixed licensing on the same site?
The driving factor for this is an Enterprise Org to solve: https://jira.atlassian.com/browse/CLOUD-10325
But I'm not sure this will actually work they way they want. Any help answering this would be much appreciated.
Also, if the true answer is to contact support, I'll do that and update this question with the response.
Yes, you can run a mixed environment like that, I actually have the exact same set up. We get Confluence Enterprise as part of Atlassian Together, and Jira/JSM are still on premium.
Awesome! Thank you @Mikael Sandberg! I really appreciate the answer.
Hey @Mikael Sandberg yes you can run a mixed environment, but what we really want to know is if you have access to "Disallow new products" for Jira and JSM on this screen:
https://admin.atlassian.com/o/YOURORGID/product-requests/settings
We run a few orgs and have mixed license levels on different products.
Hey @Shawn Doyle - ReleaseTEAM
For us, the $48,000 question (cost to upgrade a 300-Agent JSM Premium instance to Enterprise) is with only one Enterprise Product whether you can edit the Product request settings for ALL products. Because if the text of the page is to be believed, you can only do it for products with an Enterprise subscription.
(In other words, there's no "cheap" workaround to this problem.)
Because if not, then as I calculated here, the cost to upgrade our Confluence and Jira instances would be $384,000/yr more.
(SO FAR nobody has created a rogue JSM instance.)
@Darryl Lee I think you are right it is only with products at the enterprise level.
Looking forward to the answer! I haven't personally been in this situation.
Also, CLOUD-10325 makes me sad. 😢
Yeah.. and unfortunately we have been seeing too many new sites being created to continue letting it happen.
