×When we search for documentation and articles related to the customer portal, we usually find information that helps agents and administrators to customize and use it, but there are no tutorials about how a Customer can use the Portal.
Due to this question, I decided to create this guide for all customers that never used the Customer Portal before or still have questions about the available options. Thank you @Rojan Koc for this amazing idea!
So, if you want to learn more about the features and how to use the customer portal as a customer, you’re in the right place.
Once your administrator adds you to the project, you will receive a notification to finish setting up your account and the link will redirect you to a page to set your Full name and Password.
Once you click on Save and Continue, you will be logged in and see the available request types of the project you were invited to.
Note: There are some cases where the administrators allow customers to create their own accounts, so if they share the link to the portal, you can create our account by clicking on Need an account? Sign up, add your email address and click on send link.
The notification will be the one below:
Clicking on the link redirects you to a page to add your full name and password.
When you are invited to a project, the first login will redirects you to a page like this:
If your administrator gave you access to only one project, your main page will look like this:
However, if you have access to more than one project, the main page will show the projects' names:
To go to the main page, you can click on the top left that usually is the name of the company or an icon.
Note: Sometimes the administrator can share announcements in the portal and it can be shown on the main page and also on the project’s page (first screenshot of this section).
On the top right you can find your Profile icon and by clicking on this icon you will see the option Profile and Log out. Click on Profile to edit your information.
To create tickets, we need to select the project and also the request type. On the main page, click on the desired project and you will see the list of request types.
Once you select a request type, it will show the form for you to fill and send it to the support team. Each form will have different fields and options, it will all depend on how your administrator configured.
After sending the request, you will be automatically redirected to the ticket:
Add a comment:
The editor below has some options for you to edit your text and others like add links, images, code blocks, tables.
Share a ticket:
If your administrator allows, you can share the ticket with other customers or organizations.
Change status:
Depending on the project type, you will be able to change the status of the ticket.
Enable and disable notifications:
If you were added as a participant of a ticket or even as a reporter and you don’t want to receive future notifications, you can disable it.
Check approvals:
Usually, the status is Waiting for Approval and on the ticket, you can see who are the people that need to approve your request.
Some administrators link Service Management to Confluence to provide articles that may help you to resolve the issue on your own.
There are four ways to find articles in the customer portal.
1. On the main page, by using the search box:
When you start typing, it will load three articles related to what you are searching for.
2. By clicking on the magnifying glass on the top right:
This icon appears when you are not on the main page.
3. While creating a ticket:
When you type something on the Summary field, it will show three articles related to the text you just added.
4. Category:
The last option is what we call Category that is a group of articles that the administrator organizes to show when you click on the project to create the ticket, so instead of showing the Request types as mentioned on the How to create tickets section, it will show the categories and if none of the articles helps, then you can just go ahead and create the ticket.
List of categories:
By clicking on a category, you will see the list of articles and to view the entire documentation, just click on the desired one.
If none of the articles help, then click on Need to raise a request? Contact us. which will redirect you to the Request types page.
There are four categories that we can split the requests in the customer portal.
Tickets where you are the reporter.
Tickets where you are the approver.
Tickets shared with your organization.
Tickets where you are a participant.
On the top right, click on Requests.
Tickets you created:
Click on Created by me. The default filter will show tickets that are still open and then you can filter to show the closed ones or filter by specific request type.
Tickets waiting for your approval:
Tickets shared with your organization:
If your administrator added you to an organization, it will show on the Requests the name of the Organization and if some ticket is shared with this org, it will show there.
Note: When you are part of an organization you can share the request with them while creating a ticket. The option will be visible as the last field of the form, near to the Send button.
Tickets where you are a participant:
If your teammate shared the ticket with you, click on Requests > Created by me or Requests > All and filter the tickets where you are the participant.
With the recent updates of Service Management, is now possible to change the order of the columns on the requests page.
Click on Requests and select the preferred option.
On the right side on the top, you will see the icon , so click on it and select “Manage columns”.
Once you do that, you will be able to drag and drop the fields to organize and also remove those ones which it's not necessary for you:
There are other fields available, such as Created date, Updated date, Due date, Assignee, and Priority but only the administrator can add those fields.
Edit issue.
Delete images and comments.
Delete issues.
Advanced searches using JQL.
Online chat.
Ability to view the email addresses of the assignee and participants.
Hope this article helps you to understand how the Customer Portal works.
If you have any suggestions or questions, we are happy to help!
Warm regards,
Angélica Luz
Angélica Luz
Support Engineer
Atlassian
Porto Alegre, Brazil
1,776 accepted answers
5 comments
