🎉 New! Access form and form fields with smart values in Jira Service Management
Hello Atlassian community ðŸ‘‹
We’re excited to announce we’re now supporting smart values for Forms in Jira Service Management. Eliminate manual data entry and leverage dynamic data by accessing smart values on submitted forms on issues. Not only can you now retrieve form data in Jira Service Management, but can also use these values to power automations and fuel reporting. Read more about accessing smart values
Here’s how it works
Access smart values using the Forms submitted trigger
You can access submitted forms on issues when using the Forms submitted automation trigger by using {{forms}} to format the value of forms in a list when setting up a rule. To access a specific form from a list, use the automation lists smart values to retrieve the form you’re after. You can also combine, reformat, and manipulate smart values to suit your specific needs.
Example
John wants to create an automation rule that adds a comment with onboarding notes whenever an ‘Employee Onboarding’ form is submitted.
Before he creates this rule, he needs to make sure the ‘Onboarding notes’ field in the ‘Employee Onboarding’ form has a field key. He makes this ‘onboarding-notes’.
He now navigates to Automation to create this rule and selects the Form submitted as the trigger and ‘Employee Onboarding’ as the form. He then adds the action Comment on issue and enters {{forms.last.onboarding-notes}} as the comment.
Now whenever an ‘Employee Onboarding’ is submitted, the value from the ‘Notes’ field will be added as a comment on the issue.
Access smart values without using the Forms submitted trigger
You can also access any forms on an issue by using {{issue.forms.<UUID>}} and referring to automation lists smart values. These will be grouped by their Universally Unique Identifiers (UUIDs) and be returned as a list. The UUID can be retrieved from either the Forms REST APIs 'Get project form index', or by inspecting elements on the Forms landing page and accessing the UUID via the Network tab.
Example
John wants to create an automation rule that adds a comment with an employee’s latest salary to an issue.
Before he creates this rule, he needs to make sure the ‘Salary’ field in the ‘Payroll setup’ form has a field key. He makes this ‘payroll-salary’.
He now navigates to Automation to create this rule and selects the Manual trigger from issue as the trigger. He then adds the action Comment on issue and enters {{issue.forms.f7142b07-d3a4-4522-a7e4-8799d526e0a6.last.payroll-salary}} as the comment.
To get the UUID for ‘Payroll setup’ form, he goes to Forms and inspects elements to find the UUID in the Network tab.
Now whenever multiple ‘Payroll setup’ forms are on an issue, the value from the ‘Salary’ field on the most recent ‘Payroll setup’ form will be added as a comment on the issue.
Let’s break down the {{issue.forms}} smart value.
What’s next?
Our team has been hard at work bringing this highly requested feature to Jira Service Management. Based on your feedback, we’ll be taking note of any future updates you’d like to see, so add comments below if you have any questions or feedback for the team.
36 comments
Fabian Lim
This is beautiful! Thank you!
Like • Tomislav Tobijas likes this
Tomislav Tobijas
Very nice improvement and a great step-by-step article!
Kudos to everyone involved in this release 🎉
Like • # people like this
David Foote
November 13, 2024
If you run automation and log the {{issue.forms}} it will also give you the UUID of the form.
Right now it looks like when you access a checkbox field it just gives the id of the selection, not the associated value. Are there any plans for future enhancements to give us back more data?
Hanh Pho
November 13, 2024
Hi @David Foote, please refer to the Access smart values for forms and form fields page, on accessing the values of the different field types.
For example, a multi-choice field like a checkbox, you can access the id and the label of the last selected choice by:
{{forms.last.choiceField.last.id}}
{{forms.last.choiceField.last.label}}
Tanya Tranter November 13, 2024
Can I assume none of this wonderful functionality is going to be made available in the DC version?
David Foote
November 13, 2024
Can confirm that using label works! I assumed it would be value, like a lot of fields use.
Any chance we can get the form smart values added to https://support.atlassian.com/cloud-automation/docs/smart-values-in-jira-automation/ ?
Thanks @Hanh Pho !
Tobias H
November 15, 2024
I've been waiting for this forever, so happy to see it finally going live.
90% of all new custom fields we create are only there to be used in automations with dynamic forms, so this is very welcomed!
Fernando Eugênio da Silva
@Sam Knight , God bless you guys!!!!
This is awesome!!
Like • Susan Waldrip likes this
Tobias H
November 27, 2024
Just a question @Sam Knight, are there any plans on making it easier than finding UUID and inserting into smart values? It's great to see it working right now, but it's a real pain to find and set up. Not to talk about how hard it is to read what is happening in the smart value itself.
Dusan Kalanj
This is great! Do you maybe also support getting a value from a custom radio button? If I use the approach from the example it works super for text fields, but for radio buttons I haven't been able to get it to work by using .value. This is the last thing I need to solve my use case.
Dusan Kalanj
Never mind, found the solution in the comments, thanks!
Adit Thapa
December 9, 2024
Hi Sam, none of the field notes that I have set are appearing as smart values when I try to put together an automation using the example you have included. Am I missing something?
Tom Horton
Is it possible to set the Fixed versions field to a calculation when an issue is Resolved? I manually set the Fixed versions to the current year and work week, in the form of 2024.50. Automating this would be great.
Evert Morren
Is it possible to use the smart values in reports?
If yes how can I do that?
Max McFarland
December 12, 2024
This is fantastic! Is there any way to count the number of questions on a form and do branching?
Kristján Geir Mathiesen
Sweet! Thank you.
Dimitrios Kouroumichakis
Hello everyone,
thanks in advance for the function :)
I'm trying to show the corresponding fields in a comment from a form with the checkbox.
I have used the following:
{{issue.forms.UUID.last.Label}} but I only get a number, what exactly am I missing so that the text is displayed when I click on something from the checkbox.
Best regards
Owen Scott
Question — does the forms submitted trigger happen on issue creation? If I complete a form in the portal, which creates a JSM ticket, it's not triggering the "form submitted" action and my automation isn't firing 🤔
Adam Buckingham December 23, 2024
Are there plans to be able to access form values other than with the trigger "Forms submitted"?
ie. any ticket with a form attached?  This would be the awesome if we could.
David Foote
December 23, 2024
Tim Maldonado
January 6, 2025
End of last week I was able to use the following Smart Value {{forms.last.security-group}}. This field is attached to Asset object. The field is a multi-select value. Smart value would return the Key value ex. SAN-12345, SAN-23456. Worked on Friday that way. Today, I am experiencing the output as the key looking like this - 6a645022-53bc-45e9-804d-ea52185c24446:472. Did something change?
Tejas Patil
@Hanh Pho
is there a chance there is typo in your comment?
Should it be like below?
{{forms.last.choiceField.id}}
{{forms.last.choiceField.label}}
Nevertheless, I tried both options but nothing seems to be working for me,
tried to check the values in logs, but returns empty.
Tejas Patil
Never mind, I was using manual trigger to test the function, but it should be form submitted.
Kelby Corr
January 7, 2025
@David Foote I noticed this too, but for some reason it gave me a differen UUID than the real one I found when inspect elements shown in the steps above.
Hanh Pho
January 7, 2025
Hi @Tejas Patil
Regarding the choice field values
Since a choice field can have multiple selected options, its selected options are in a list. In my example, we only wanted the last selected option. You can get the last item, the first item, specific item, or loop through a list using these Jira Automation list operators
Like • Tejas Patil likes this
