Unlock more value of your ITSM processes with group-based assignments in JSM
Hi, all!
Today we would like to discuss with you the Assignment Group concept, which we successfully implementing for our customers.
As you know, out-of-the-box Jira Service Management (JSM) doesn’t support the concept of shared responsibility – everything is driven by single-person responsibility via leveraging the “Assignee” field. However, many teams, especially the ones following ITSM practices, may experience the need for the functionality enabling ticket assignment to groups or teams, while working on projects. Yes, there is an Atlassian Team concept, but unfortunately it was not intended for working with assignments.
Realising the frequent need of using team- or group-based assignments on tickets, as well as to enable notifications of corresponding teams or ensure extra security by leveraging issue security levels coupled with group assignments, we created the Assignment Group concept. First, we tested it on our internal projects and later began to suggest using it to our customers, who also expressed their need for such functionality since their work on requests was usually distributed among groups.
According to the developed concept, the “Assignment Group” field is a custom field of the Group Picker type, which contains a list of Jira group names with members. Based on the value of the "Assignment Group" field, JSM can be configured to use this field for:
  • Automatic assignments
  • Indication of who is working on a ticket right now
  • Sending notifications to all members of the group
  • Clearing the “Assignee” field when the “Assignment Group” value is changed
  • Displaying team-based queues
  • Configuring security levels, and more
Here is a short guide on how to use the Assignment Group concept on your project:
  • Create a set of groups in Jira user management, add members to these groups. All members should have a JSM license. We recommend using Atlassian Access for user management across all Atlassian products and configuring groups provisioning from your user identity provider. This way you minimise the time you spend managing users in the groups
  • Create the “Assignment Group” field of the Group Picker type (the field will pick up the groups created during the first step) and associate the field with corresponding screens. N.B.: The “Assignment Group” name of the field is just an example, you can choose whatever name you want
  • For the tickets routine, you can configure a rule, which automatically sets the “Assignment Group” field. Alternatively, if an assignment is based on request types, it can be added as a hidden field in a request type in JSM
  • For notifications sending, modify the notification scheme by including “Assignment Group” in corresponding actions (create/edit/resolve)
  • For an easier ticket routine, you can create a set of JSM queues based on assignment groups
  • For additional security, you can configure security levels based on “Assignment Group” values
As a result, you have well-functioning team- or group-based assignments along with additional reporting, which you can use for further analysis.
Have you experienced the need to set group assignments in Jira? What do you think about such an approach, would you like to test it on your ITSM project? Share your own life hacks and ideas on alternative workarounds and feel free to ask any questions.
8 comments
Dirk Ronsmans
December 15, 2022
Hey @Nadia
Coming from using and implementing other tools for ITSM we do encounter the absence of a group assignment very often.
We've tried the same approach as you but do stumble on to a few issues with it.
  1. How do you filter what groups are available in the list? Jira comes with a lot of out of the box groups and security groups which we don't want to show in the list.
  2. How do you link the Assignee to the Group? At this time there doesn't seem to be a way to filter the Assignee field based on what group was chosen so you could still be assigning an issue to a user that is not a member of that group. (self-assignment solves that but still not really perfect)
To solve 1. we tend to use a Insight Custom field where we define the groups inside an object schema so we have full control over the list ourselves but still no way to solve the assignee filtering.
We do work a lot with the idea of "assign to a team and the team must choose who take on the issue" and however this is very silo-based thinking it's still the way of working for a lot of companies and teams.
Like # people like this
Nadia
December 16, 2022
Hi Dirk,
Thanks for your comments!
If you’d like to filter the groups, there are couple of options:
  1. Using Assets (Insight) based custom field as you described - absolutely great workaround, as filtering is just there. However with the Assets you may get some limitations with the reports - Asset objects are not recognisable in the excel exports (hopefully though Atlassian will correct it soon), and may not work with all dashboard gadgets yet.
  2. Another option is to use automations and another select list field together with the group picker field, with the mapping between these 2. So any time you set assignment group, you set both group picker and select list field values, and synchronise them if any changes. Here is the example automation rule to sync both fields: Populate Assignment Group.png
As for the linking assignee to the group, my college recently published an article describing how you can filter assignee based on the assignment group, please find it here (you’ll be interested in Scenario 2: group assignment). Do hope it helps
We are at your service, if you have any further questions.
Dirk Ronsmans
December 16, 2022
Interesting approach on the group filtering. I believe using either an Assets field or select list would be the same (just differently in the automation) but it would indeed still allow you to use the build in groups in the background (while filtering out the groups in the select list)
We prefer using Insight/Assets as it allows us to give control to a user/group to edit/add/remove groups without the need to be admin on the system (to change custom field options)
I just read the article from your colleague and also a nice approach but sadly you can still select the wrong person (and the list would also be super long on larger instances) but it would at least prevent the wrong member to be set.
i'm still waiting on the Team field that Atlassian is building (currently EAP for JSW) which would allow us to truly filter and do group assignments..
Ragini Sharma February 2, 2023
Hi All,
Even I want to explore "Group Assignment" functionality using Insight. Lets see how it goes and how much can I solve.
Deleted user March 17, 2023
Hi everyone,
I've just started my Jira Service Management journey and have what seems like a million questions. I've been tasked with setting JSM up and presenting to the rest of my colleagues. At the moment we are using a demo promotion of JSM Standard so things like Insight aren't available yet.
My first question ist in my JSM project in the top menü under People, I can create different teams but I can't figure out how to access them in my incident mask.
After reading this article, my next question is; Why have you created Groups? Is it because the Teams are not accessible?
Sorry for asking such beginner questions but I could really use the assistance.
Dirk Ronsmans
March 17, 2023
hey @[deleted] ,
A team in Jira is not something you can use (yet) in your projects/processes.
They are more a logical grouping of users that work together so you can have a nicer follow up/ teampage/...
There is a little more details here:
https://support.atlassian.com/atlassian-account/docs/what-is-an-atlassian-team/
Hi @Dirk Ronsmans
Thanks for the Team explanation link. Now Iknow a little more than before. Hopefully Atlassian will expand a team to more than just a "social circle". It's the logical object for what I'm trying to do.
I guess I'll have to try your method of creating a new object schema or some other method. I have to justify the change to Jira before I can get my hands on the Premium version and that is only possible if I can convince the Powers-That-Be that JSM is really what we need.
Thanks for your time and help. =^D
Jamie Jones
November 25, 2023
I would be cautious when considering the use of Teams as a solution for assigning issues to specific groups. My interpretation of Jira's documentation and specifically as it relates to the line quoted below, is that if you decide to delete a Team, it will also be deleted from all historical transactions and anywhere in Atlassian that the Team may have been referenced. (i.e. the correlation between an issue and the team/team member that resolved it would no longer exist)
"The team will not appear in search results across Atlassian products."
Such a possibility might be slightly less worrying if it were possible to manage Teams centrally (e.g. synced to AD groups) or at least a subset of them as required to manage work assignment in JSM . It seems however that the Create Team button is open to everyone and all members of a given team have the ability to delete it.
Create and manage an Atlassian team | Atlassian Support
If historical reporting and the ability to track performance across resolver groups as well as the individual members of those groups isn't a functional requirement for your organization then Teams might be a suitable option.
