Since I know JIRA is taking the whole email body as issue description, I'm now trying another approach where the email message body is formatted in a form format like
Name : User Name ,
Field 1 : Field Data 1 ,
Field 2 : Field Data 2 ,
Issue Description : Description
My approach is now using JIRA Service Desk Automation :-
My questions are :
1) Since the issue description is now formatted, is it possible to use say, regex((([\w\s\d]+) (:) ([\w\s\d]+) (,))) to grab the data and remove the field name string, so the resulting string contain the field data?
2) Does it mean I have to do multiple branches for selector and option (dropdown) data? T.T
3) Any other approach that will take less time developing and configuring (even if it's an add-on) is welcomed?
I do know about Automation for JIRA add-on but i would like to fully use JIRA as much as possible w/o plugin (unless it is impossible and a plugin is the only way)
