So I've been trying to tinker with running scripts through JEC, but I can't find anything at all about how to use JIRA data as a parameter for my scripts.
Yes, I can send the data to JEC as a key-value pair.
But how in the name of $deity do I use those key-value pairs in JEC to forward them as parameters to my script? I know it's something in "args", but I've no idea what the correct "grammar" is, and as usual, the example provided by Atlassian is lackluster.
The video Atlassian provided explaining this feature (in What's New in Jira Service Management - April 2024 (atlassian.com)) also comes short, showing how I can set up the key-value pair, but not how to configure my JEC JSONs to use those values.
Has anyone managed to get this working, and could shed some light on this?
Thanks in advance for your time.
Ok @Iker Gómez Eiras After reaching out to helpdesk and tinkering around I've made progress. I created a powershell script that outputs $args to a text file and found that I got four arguments.
-payload
{"actionType":"custom","activationId":"XXXXXXXX-XXXX-XXXXX-XXXX-XXXXXXXXXXXX","action":"SimpleNotifyTeams","requestId":"XXXXXXXXX-XXXXX-XXXXX-XXXX-XXXXXXXXXXXXX","sendCallbackToStreamHub":false,"args":"Args String","Message":"Message String","List":["List Value 1","List Value 2"]}
-apiKey
XXXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXXXXX
-jsmUrl
https://api.atlassian.com
-logLevel
DEBUG
In my case I would have to take that -payload param, convert from JSON and THEN I could get to the three key pairs I actually passed to the script (args, Message, and List). Powershell is the only language I know well, So I'm sot sure how this would work in Python or what have you, but there you go. If there was ANYTHING in the documentation to suggest this was how this would work I did not see it either.
@Gabriell Valentine Honestly, I kinda gave up on this -- moved on to other tasks, decided to wait until either the community or Atlassian properly documented it. Or my company decided to use other tools.
Just tried and yep, had to add a "$payload" param to my script (I also use powershell) which provides the whole thing. Thanks!
I'm really happy to know I'm not the only one struggling with this. It would be really helpful is there were somewhere I could send the incoming JSON so I could figure out what is actually being sent when I pass along those key pairs. The documentation is pretty confusing and there doesn't seem to be any other online resources for figuring this out. I'll keep testing and If I find anything I'll let you know @Iker Gómez Eiras
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
