Hi, the title basically says it all but it would be extremely beneficial for myself and my team if the ability to move requests to different projects as needed could be developed for Jira Mobile (I use iOS).
If implemented (along with the bug fix to allow for Request Types to be edited which I've been told is coming), I would be able to use Jira for iOS for the vast majority of my JSD work, which would be awesome!
Evan
@Evan Gilner The ability to move issues is not yet available on mobile. I would suggest submitting a feature request here: https://jira.atlassian.com/secure/Dashboard.jspa
The ability to change request types is available but you can only change them if they share the same issue type.
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →Online forums and learning are now in one easy-to-use experience.
