Problems with setting up approver in workflows
Tri-Sang Vo November 15, 2024
I just want to setup an Service request with a approver group, where someone in this group has to accept the request.
The service request is created through a request form in the portal.
The request form is available for everyone, who has access to confluence.
I created a custom field with Group Picker (single group) and added it to multiple screens, context and projects.
My problem is, that I cannot see the custom field in the workflow scheme.
What am i doing wrong?
Tomislav Tobijas
Hi @Tri-Sang Vo ,
Single group picker custom fields are not available as approval sources (yet). I've managed to find this request on JAC - JSDCLOUD-14900 Ability to add single group picker field to Approvers but I think there's another one (with a lot more votes). You might try to check out the following filter.
Anyway, the 'workaround' would be to use a multi-group picker field instead of a single select one.
Tom
