Ternary operator (or if/else) with smart values
Chad Waldman March 10, 2023
I'm looking to create a smartvalue that would say:
If (field.match(".+Multiple.+")) Then 20 Else 2
I could do:
{{#if(issue.field.match(".+Multiple.+"))}}20{{/}}
however I don't know how to do the fallback value.
Is this possible with a smart value?
FWIW, I already know I can do this in Automation with an If/Else.
Aron Kuch
I used the double-if and it seems to be working.
{{#if(equals(issue.issuetype.name, "Large"))}}10000{{/}}
{{#if(equals(issue.issuetype.name, "Program"))}}10002{{/}}
James Navin
March 12, 2023
Hi @Chad Waldman ,
Ternary expressions aren't supported in Smart Values at the moment.
To achieve what you're looking for there are a couple of options:
  1. Set the value to the "fallback" and then use the 'if' to override it
  2. Use a second 'if' with a `not()` function to set the fallback for the negative case
Hope that helps,
James
Chad Waldman March 12, 2023
Thank you for the suggestions.
I am not following your first recommendation. Can you please write an example.
For your second suggestion, are you recommending:
{{#if(issue.field.match(".+Multiple.+"))}}20{{/}}{{#if(not(issue.field.match(".+Multiple.+")))}}2{{/}}
I haven't tried two conditionals in one expression but this sounds interesting.
MJCorcoran
I needed to put an email address (created from values in the issue) into the ticket comment, but needed to use 2 different logics to create the address based on whether there was a middle initial (customfield 12034 in this example). I followed the 2nd suggestion above and came up with something like this. What I am trying to figure out is how to get them all in one line/statement so the answers don't appear spaced differently depending on the logic.
{{#if(equals(issue.customfield_12034.value,"NA"))}}Email Address: {{issue.customfield_11884.left(1)}}{{issue.customField_11885}}@kennedy-center.org {{/}}
{{#if(not(issue.customfield_12034.value,"NA"))}}
Email Address: {{issue.customfield_11884.left(1)}}{{issue.customfield_12034}}{{issue.customField_11885}}@kennedy-center.org {{/}}
Register now
