Validator on Create issue not working.
Nick Hassell
February 25, 2020
I want to ensure that all issues of a given issue type are created via the Portal.
I have Cloud ScriptRunner and have written a Workflow Validator as follows:
(issue.properties['request.channel.type']['value'] == 'portal') ? true : false
I have successfully tested this against existing issues.  However, when I add this condition to the Create transition, it always returns false.  If I change the if condition from 'portal' to null, then it still returns false.
Am I doing something wrong?  Are there any alternatives?
Viktor
I have a similar issue.
Validator works when testing with JMWE addon, that is, making sure Reporter is in a group.
However, it has no effect on Service Desk portal and everyone can create the request type.
Radhika Vijji _Innovalog_
May 29, 2020
Hi Viktor,
Can you share what you configured? What you need is a Build-your-own validator with the following Jira expression:
user.groups.includes("jira-users")
It should block the user from creating the issue, but the error message displayed is the standard message and not the message configured in the validator. That is a known issue in Jira Cloud.
Radhika
Like Viktor likes this
Viktor
Thank you.
Turns out I misclicked when I selected the Workflow issue type scheme.
Works now, but the validation error message, unfortunately, is not displayed on the portal.
Nick Hassell
February 26, 2020
On doing some more testing, it seems that issue.properties is null on issue creation. I guess this is by design?
Marini Marini
August 4, 2023
@Nick HassellDone a few tests too. I think you are right. issue.properties value will be set after the issue creation. Thus, there is no way for checking if a user tries to create an issue from Jira/portal/API using a validator in Create issue transition.
