Automatically link tickets by a issue comment
This workaround is meant to help JSM, JSW and JWM projects where it is necessary to link Issues mentioned in a comment.
At the moment, this functionality isn't available natively in Jira, we have a request feature created for this topic:
Workaround steps:
  • Automation rule:
    • First, it will be necessary to create an Advanced compare condition for the comment with the desired project Key, with this smart value{{issue.comment.last.body.text}}Screen Shot 2022-10-10 at 17.33.59.png
    • It will be necessary to create a variable, "test" for example with this smart value and regex validator{{comment.body.match("([A-Z]{2,}-\d+).*")}}Screen Shot 2022-10-10 at 17.35.09.png
       Note:
      I recommend not using a variable name with any word that could be related to some Jira property, as this will make automation not work (I found this out by doing several tests using the word "issue" until I used the word "test" which worked).
    • So the icing on the cake here is to add a Link issues action into the automation rule using the variable that we already create with this smart value: {{variable_name}}Screen Shot 2022-10-10 at 17.36.38.png
    •  Extra tip: if you want to link tickets from different projects by a comment, just change the scope of the automation rule to Global(All projects for Multi projects):Screen Shot 2022-10-10 at 18.06.02.png
Now the ticket mentioned in a comment will be automatically linked. The automation rule will work as in the screen recording below:
12 comments
Bhanu
October 10, 2022
This looks like a great feature to have. It reduces an extra step to link the issue manually. Thank you for sharing this @Bruno Altenhofen
Like Bruno Altenhofen likes this
Bruno Altenhofen
October 10, 2022
Hey @Bhanu
Thank you for your feedback! :D
Like Hasini Katta likes this
Charles Trilha
October 11, 2022
Very nice article!
Rick Toffoli October 11, 2022
Amazing! This feature will help a lot our Jira site.
Thank you for share @Bruno Altenhofen
Bruno Altenhofen
October 11, 2022
Hey @Rick Toffoli
David Berclaz _Apwide_
October 14, 2022
I just configured it for our Customer Portal, and I can confirm it works perfectly!
Thanks for the workaround @Bruno Altenhofen 💪
Bruno Altenhofen
October 17, 2022
Hello @David Berclaz _Apwide_
Great! Thanks for your feedback! ;)
Like David Berclaz _Apwide_ likes this
Yatish Madhav
October 26, 2022
Super! Thanks for this @Bruno Altenhofen  - I have extended the variable to this:
{{comment.body.match("([A-Z0-9]{2,15}-\d+).*")}}
To allow for numbers in the Project keys and we also have our Jira instances project keys limit set to 15.
Thanks for this. It works great!
Now to implement it across our 700+ projects if everyone is happy with this :D
Thank you
Bruno Altenhofen
November 21, 2022
Hey @Yatish Madhav
Lauren Strom
February 28, 2023
this works beautifully if you only mention one ticket! what if you're mentioning multiple tickets in one comment?
i.e. your comment is: "following up for feedback on FORM-1 and AFJ-1"  ?
or
i.e. your comment is: "following up for feedback on AFJ-1 and AFJ-2"  ?
tk June 2, 2023
thanks for the doc.
I can't believe this is not available native (jira server had this forever and it also removes the link when comment is deleted or updated)
Mark
June 16, 2023
@Lauren Strom this works fine in my case assuming XXX in my project prefix. This works for tickets mentioned after each other or on new lines.
{{comment.body.match("(XXX-\d+)")}}
I have added 4 automation rules: ticket created, ticket updated, comment added, comment updated.
  1. Trigger: Comment Created or Updated
  2. Not sure if necessary: but with regex: {{comment.body}} contains regular expression `XXX-\d+`
  3. Create Variable: {{ticketNumber}} with smart Value `{{comment.body.match("(XXX-\d+)")}}`
  4. Link Issue To: Relates to `{{ticketNumber}}`
Issue
  1. Trigger: Issue Created or Updated
  2. Not sure if necessary: but with regex: {{issue.description}} contains regular expression `XXX-\d+`
  3. Create Variable: {{ticketNumber}} with smart Value `{{issue.description.match("(XXX-\d+)")}}`
