Sign up Log in
Code in Jira now supports GitHub, GitLab, and Git Integration for Jira for classic and next-gen
Hi Atlassian Community,
I work on the Jira Software product team and I am happy to share that we have just added support for third-parties, such as GitHub and GitLab in Jira Software Cloud’s Code in Jira.
Available for both classic and next-gen projects, Code in Jira enables everyone on your team to automatically view the repositories that are being worked on across Bitbucket, GitHub, or GitLab right within Jira. When a team member includes an issue key in their commit, branches name or PR summary from your source code management of choice, we will automatically parse out the repo in which that activity occurred and display it on the Code in Jira page!
Connect to your third-party Git tool in just three steps
We’ve brought the third-party Git connection flow right into the Code in Jira view to make integrating as frictionless as possible. To get started, following these steps:
  1. Simply click through on the “Connect to another Git SCM tool” button.
  2. Select the provider you wish to integrate with (or browse the list of available apps) such as GitHub or GitLab.
  3. Click the “Get it now”and follow the app install prompts.
  4. Once the app is installed and configured all you need to do is include issue keys in your branch names, commit messages, or pull request summaries and the repositories in which this dev activity occurred will automatically appear on the Code in Jira page.
Enhanced admin controls in Jira
We’ve also added a Code toggle on the Features tab for greater flexibility and control. Turn Code in Jira on or off for your entire team by visiting the Features tab.
Once you have a third-party app connected, easily navigate to your app settings from within the Code in Jira view.
Next up
Next up, we’re looking into adding more granularity to the Code in Jira tab by showing additional repository information on the cards, showing open Pull Requests, and more. Stay tuned for more updates in the coming weeks and months!
We’re looking forward to seeing how you use these new features. Please let me know if you have any feedback or questions on this feature, we would love to hear from you!
Learn more about this feature in our documentation
20 comments
Drew Cottrell
@whammy  I just tried checking it out but seems it doesn't work with the DVCS Connector which is still the only way to connect to Github Enterprise.  Unless I'm missing something?
There were hints that Github Enterprise support would be added to new tools back in 2018 but it never happened.
Taranjeet Singh
November 22, 2020
Is this feature only available for Jira Cloud? or Jira Server/DC as well?
Like Serena Heil likes this
whammy
November 22, 2020
Hey @Drew Cottrell unfortunately the Code page doesn't support GitHub Enterprise at this stage, however we have logged the request with the GitHub team and we will follow up with them. I'd also recommend submitting this request to the GitHub team via: https://support.github.com/request.
whammy
November 22, 2020
Hi @Taranjeet Singh this is only available for Jira Software Cloud at this stage.
Drew Cottrell
@whammy thanks but that's a lame response, we've been asking both Github and Jira to provide better support for this for years but have been told that the focus is on newer features instead and there's no intention to ever provide a means for us to stop using the old DVCS connector.
Jonas Lerch
November 25, 2020
@whammy which enterprise is meant? Only the on-prem or also GitHub.com enterprise plan?
Marco Borm November 26, 2020
Can this be extended by a developer? So: How can a integration plugin/extension for other source repository providers be created for Jira Cloud, on the same level of integration as this GitHub integration?
Like 2 people like this
Hycinth Umaran
November 26, 2020
Why can't I see in our JIRA instance-> code the option to "Select a source code management tool' as per your figure 2?
Like Ahmad Hammad likes this
Tony Vlcek
Hi, I'm looking into the GitLab integration and it's now only supports GitLab.com is there a plan to add support for self-hosted GitLab instances?
Like 5 people like this
Dennis Sawin November 26, 2020
Hi, are you at some point going to show GitLab Deployments and Pipelines?
Leng Be November 29, 2020
Hi, will you also providing integration to Azure DevOps?
Like stephen.metts likes this
Marco Borm November 30, 2020
Hi @whammy can you please answer some more questions from your community here please? Isn't that what a community is? Something with working and talking together and not some target for press releases.
whammy
November 30, 2020
Hey @Jonas Lerch just the on-prem version, the cloud version is supported.
whammy
November 30, 2020
Hi @Marco Borm thank you for your patience.
Yes this can be extended by a developer through other apps via Atlassian Connect for cloud or OAuth for on-premise tools.
Here are some details on how to achieve this:
https://developer.atlassian.com/cloud/jira/platform/getting-started/
https://developer.atlassian.com/cloud/jira/software/rest/api-group-development-information/
whammy
November 30, 2020
Hi @Hycinth Umaran just want to make sure I understand correctly that you don't see the Code page in your project navigation? If that's the case you can turn on this feature in your project settings.
Next-gen projects: https://support.atlassian.com/jira-software-cloud/docs/enable-code/
Classic projects: https://support.atlassian.com/jira-software-cloud/docs/link-repositories-to-a-project/
whammy
November 30, 2020
Hi @Tony Vlcek currently that's correct only GitLab.com is supported, however we are currently talking with the GitLab team about adding support for self-hosted versions of GitLab. Keep a look out for an update.
whammy
November 30, 2020
Hi @Leng Be this is currently not supported by the Azure DevOps app, we would recommend reaching out to Azure DevOps directly via the available support channels to request this feature: https://marketplace.atlassian.com/apps/1220515/azure-pipelines-for-jira?hosting=cloud&tab=support
Thank you @whammy !
Samuel Araiza
Thanks, @whammy . Been desiring these features for years.
I don't currently see the "DEVELOPMENT" section of an issue until I have created a branch on GitHub through their site—that's when I can view the branch, commits and pull requests. I can't seem to figure out how to Create branch from the issue itself as displayed in the image. Any advice?
Hycinth Umaran
December 8, 2020
@whammy Thank  you for sharing related links. Just to reconfirm that in order for us to successfully install and setup, we must have GitHub Enterprise account. Is this correct? Otherwise, we cannot perform linking even JIRA issues with Open issues in GitHub?
Upcoming Jira Events
