We’re excited to announce meaningful efficiency and performance improvements in Jira Software’s board and backlog on company-managed projects, designed to help you and your team work smarter, not harder.
Alongside a fresh look and feel, here are some of the enhancements you can look forward to…
Issue details can be edited directly on the backlog. Simply select an issue’s summary, assignee, status, parent, and priority field to edit. If you're working on a Scrum project, you can also edit the story points field.
You can now take more control of the way you view your work.
You can control certain fields that have been added to the card - for backlog it is the status, epic (parent), and version field, for board it is the epic (parent) field. We will add to this list of fields over time.
In the backlog, you can select compact mode to reduce the height of the cards which will allow you to see more cards on your screen at one time.
There are toggles to show or hide the epic and the version panel.
There is a toggle to display Quick Filters as a horizontal row or to keep them in the Quick Filter dropdown to save on vertical space.
You can now perform bulk changes without having to leave the backlog or open individual issues. With a few clicks, you can change the priority, assignee, labels, and estimate fields for up to 50 issues at once.
Select issues one at a time using the checkbox, or by holding "command" (for Apple devices) or "control" (for Windows devices) while you select each issue. To select a group of issues, hold "shift" while selecting. Once selected, right-click on any of the issues, or use the more actions (...) menu, then choose the bulk action you'd like to perform.
We’ve reorganized information in the epic and version panels to provide a more meaningful overview of your team's progress. You can track the number of issues in each epic or version, as well as your team’s progress for estimated tasks.
To open the epic or version panel, select the epic or version filter in the backlog, then switch on the toggle. Use keyboard shortcuts "E" and "V" to do it faster.
We are on a path to make Jira Software more inclusive. We have introduced additional keyboard shortcuts, a new command palette (cmd-k/ctrl-k), keyboard support for filters, keyboard support for date pickers, keyboard support for settings pages, and screenreader support for menu items.
Interactions are smoother and more fluid, especially when your board and backlog have a large number of issues.
Colors have been improved for accessibility — you’ll notice this on flagged issues, column constraints, and the progress bar in the epic and version panels.
When you filter by sprint, issues assigned to you, and recently updated issues, the results will appear instantly.
When moving issues on the board, transition names are shown as dropzones in each column. If your board has multiple workflows, this helps your team better understand how work flows from To Do to Done.
Issues in the backlog no longer need to be paginated. Just keep scrolling to view more issues.
When splitting or flagging issues, you’ll notice a cleaner look and feel.
After auditing the board and backlog, we identified features you didn’t find useful. Due to low usage, we’ve removed the ability to print issue cards and create linked pages for epics and sprints.
Once we’ve addressed key feedback, users will have the new experience by default. This means that your feedback is incredibly important. In the enhancements menu, simply select Give feedback. If needed, and if you give us consent, we’ll reach out for more information so we can better assist you.
Eoin
Senior Product Manager
Atlassian
Sydney
46 accepted answers
468 comments
