Did you know there’s a simple way to bring existing work into team-managed projects in Jira Software?
If you have a list of work items in a document or spreadsheet, you can copy and paste the content directly into Jira, and choose whether or not to auto-create multiple issues at once. Each new line of text (or each cell in a spreadsheet or table) can automatically become a separate issue.
Copy the existing content from your external document or spreadsheet to your clipboard. (Make sure each work item/task is on a new line, or in a separate cell on a spreadsheet/table. You can have a maximum of 255 characters per task, and can copy a maximum of 20 tasks at a time.)
There are two ways to copy-paste existing work:
In a team-managed scrum project, go to the backlog, and select + Create issue under a sprint or under the backlog section:
Paste your content. You will be given the option to auto-create multiple issues (in the example below, 20 lines of text have been copy/pasted), or create a single issue (if you’ve copied less than 255 characters):
And that’s it! You can copy/paste up to 20 work items at a time.
Hannah McKenzie
8 comments
