Impact of updated cipher suites on Jira and Jira Service Management
Update on August 2, 2024
We've further extended support for the unsupported cipher suites until September 23, 2024, to ensure sufficient lead time to make the required changes.
Update on July 31, 2024
Re: Email sent on July 29, 2024, titled “[JIRA] TLS cipher suites are being deprecated by August 5, 2024”. While the intended recipients of the deprecation notice were Jira admins who have configured mail servers with Basic Authentication (excluding Google Basic Authentication), the email was unintentionally sent to all Jira admins, including admins of sites that:
  • Use mailboxes configured with Google/Microsoft OAuth or Atlassian’s Default Cloud Mail Server, OR
  • Don’t use the incoming mail feature to create new issues and comments in Jira.
If you fall into either of the two categories above, please ignore the email and accept our apologies.
Additionally, to ease the confusion regarding who it affects, we’ve:
  • Edited this community post to answer most questions in the comments.
  • Extended support for the unsupported cipher suites until September 2, 2024, to ensure sufficient lead time to make the required changes.
On August 5, 2024, Jira and Jira Service Management will begin updating their Transport Layer Security (TLS) configuration to be consistent with other Atlassian Cloud products. This includes ending support for some weaker cipher suites.
This change may impact sites using the following:
Who is affected?
For Jira:
You can verify if the deprecation notice applies to you by navigating to Jira’s incoming mail feature (cog icon > System > Incoming Mail) and locating the ‘Basic’ Authentication Type, as shown in the Set up your incoming mail server section (screenshot below).
Note: No action is required if you:
  • Use mail servers configured with Google/Microsoft OAuth, Google Basic Authentication, or Atlassian’s Default Cloud Mail Server, OR
  • Don’t use the incoming mail feature to create new issues and add comments on Jira.
For Jira Service Management:
You can verify if the change applies to you by checking if any of the service projects on your site are configured to receive new requests from external email accounts connected via Basic Authentication. i.e. If you’ve connected your external email account by selecting Other (or Continue with Other) on the Email requests page under Project Settings, then it’s connected using Basic Authentication.
  • Use mail servers configured with Google/Microsoft OAuth, Google Basic Authentication, or Atlassian’s Default Cloud Mail Server.
I’m affected by this change. What do I do next?
If the deprecation impacts your site, we will contact you before it comes into effect. If you’d like to be prepared for this change in advance, you can perform the following steps:
For Jira:
  • If your organization uses a self-hosted or third-party mail server for the incoming mail feature, contact your IT team or service provider to confirm whether they’re using cipher suites supported by Atlassian.
  • Post the deprecation, you can test the connection by going to Jira > Settings > System > Incoming Mail > Mail Handlers (configured with an already functional Basic Authentication mail server) > Edit > Next > Test. A successful test confirms that you’re using supported ciphers, and no action needs to be taken.
  • From your service project, go to Project settings and select Email requests. If you have an external email account connected using Basic Authentication, find out its incoming mail server hostname. Depending on whether the mail server for your email account is self-hosted or managed by a third party, contact your IT team or service provider respectively for cipher details.
  • Post the deprecation, you can refer to the Connectivity logs (Project settings > Email requests > View logs > Connectivity logs) to check if a connected email account is showing the status as failed due to the Remote host terminated the handshake error.
Supported cipher suites as of August 5, 2024
As of August 5, 2024, your mail servers must accept TLS connections using at least one of the cipher suites below.
  • TLS_AES_128_GCM_SHA256
  • TLS_AES_256_GCM_SHA384
  • TLS_CHACHA20_POLY1305_SHA256
  • TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
  • TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
  • TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
  • TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
  • TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
  • TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
How can I fix this issue?
For Jira and Jira Service Management, identify mail servers that are connected using Basic Authentication. Then, depending on your incoming mail server, follow the instructions below:
  • For self-hosted mail server(s), contact your IT team and ensure they use one of the supported cipher suites.
  • For mail server(s) managed by a third party, refer to the support documentation on their official website or contact your service provider. Make sure they use the ciphers that Atlassian supports.
  • If you’re using Google Basic Authentication, no action is needed as it supports the latest ciphers. However, to avoid future issues, we recommend you connect via OAuth.
* For Jira Service Management, if the service projects on your site are connected to external email accounts with different incoming mail servers, then you need to perform this check for every mail server.
We understand that system upgrades can be complicated, but keeping your data secure is our priority. We appreciate your support and patience as we turn off old, insecure cipher suites. If the problem persists, contact the support team.
62 comments
Susan Waldrip
Thank you @Ritika Arora for posting this info!
Like Tomislav Tobijas likes this
Alba Luz
July 28, 2024
No quiero que nada afecte mi correo electronico  yo no uso esas aplicacionesl
Alex Opie
July 28, 2024
I'm a bit confused about this notice and the email I got today: what exactly is changing?
The message is
> On August 5, 2024, some of the TLS cipher suites may no longer work and will affect incoming mail connections with 'Basic' authentication type.
But what connections are these? Atlassian doesn't host my email (does it host mail at all?), so why would I be making a mail connection with any authentication type, let alone "Basic"?
Like 30 people like this
Mohammad Faiz Fitri Bin Mohd Anas
July 28, 2024
hi, i've received this. please advise what is the impact to our company. please advise how we do verify if using tls and oauth. thanks
Like 9 people like this
Krishnan July 28, 2024
+1 @Alex Opie 's question
Abdelrahman Alfawaier July 28, 2024
+1
Prabu N July 28, 2024
We are using MSXML2.XMLHTTP60 component for API connection with Basic authentication. Will this be impacted? Or is it only for emails??
Joakim Baas
July 28, 2024
+1 @Alex Opie
IKP Reddy
July 28, 2024 edited
+1, Today i also received this email. Not sure what to do next ? can we ignore or do  i need to do any precautionary steps ?
I am still not clear about the email content what they mentioned..
Like 4 people like this
Chetan Chavan
July 28, 2024
Toady we also got email. Not sure what to do next ? We used Gmail services what we need to do ?
Sunil Vardhaman
July 29, 2024
We use gmail service for mail for Jira mail notifications & it supports all the ciphers (latest) which is supported by Atlassian, do we still think we need to do any-changes on our end ?
Bart van den Bosch NEXUS
July 29, 2024
We also received the email and are using JIRA cloud, Confluence cloud and Microsoft 365/Exchange Online. It's unclear what to check where.
Like 6 people like this
Jeroen van den Berg
July 29, 2024
A lot confusion could have been prevented if Atlassian stated in their e-mail exactly which settings to check. In fact, they only communicated: "Here are the ciphers we support, check your e-mail settings". Which ones?
Like 18 people like this
Gema Bejarano July 29, 2024
Buenos días , necesito saber en que afecta, esto ? Ando perdida.
Gracias.
Gugudu Mohammed Shamiullah
July 29, 2024
I have received this email in my inbox , may I know what is this email about and what impact does it have for existing Jira setup for us? Can you please elaborate briefly on this .
Like 3 people like this
Si yo también y cual es impacto. Gracias
AMOGH JAIN _RA2111027010010_
July 29, 2024
I am new here can anyone please help me in knowing what do we have to do to make sure it doesn't affect and how do we check that?
Like 2 people like this
Gürcan Serttas
It is not clear, what should be checked by admin site?
Like 5 people like this
Hannah Johnson
Can someone please let me know what i am supposed to check?
Addison Taylor
previous community post with where to see this: https://community.atlassian.com/t5/Jira-articles/Microsoft-s-deprecation-of-Basic-Auth-in-January-2023-and-how-it/ba-p/2175164
it seems also the hyperlinks for "community post" and "contact our support team" were transposed
Enoque Guimel Santos Clemente
July 29, 2024
Hello good afternoon,
I have the same doubt and query, at the level of configuration between Atlassian/Jira and our Exchanger server and application in "Enter/AD", we see everything correct, is there any more configuration or extra review to be done?
Thank so much,
Anne Saunders
July 29, 2024
Can someone from the Atlassian team post a screenshot of what a current and properly connected incoming mail server and mail handlers should look like?
I don't see either 'Basic' or anything about ciphers anywhere, and the 'Authentication Type' field on the Default Cloud Mail Server (our incoming mail server) is blank.
We do use SSO to authenticate to Jira as individuals, but the email is unclear regarding whether this is the security setting meant.
Like 7 people like this
Sutherland, Melanie
July 29, 2024
If someone can advise if we are affected by this please? I have no idea where to start looking.
Michael Poole
July 29, 2024
The "Supported security protocols for Atlassian cloud products" page (as of this writing) only says that "This affects all secured traffic (HTTPS) to Atlassian cloud products".  It doesn't address email traffic at all.  Adding information about how email is affected might reduce the confusion about how this applies to mail servers and email exchanges.
David at David Simpson Apps
July 29, 2024 edited
This email is incredibly badly worded.
Perhaps have someone translate it for normal users into why they are receiving the email, what if anything needs to be done, and why.
Also the email states nothing about the service it regards or the URL of the Jira in question.
This thing is going out the thousands of users. Each one of them will then have to try to understand why they’ve received it and what it means. Just think of the number of wasted hours.
Like 26 people like this
